New 3rd gen build
CHIP
Re: New 3rd gen build
Post by CHIP »
While speaking about inputs, why do the input layouts for #124 and #102 differ from #183 , 2nd and 3rd generation, in the fact that the former 2 don't have a separate wire running to the preamp chassis ground?
Nice job Sonic!
That looks great! :D :D
Dr d
Post by Dr d »
Nice Build....some sound clips would be awsome!
dcribbs1412
Post by dcribbs1412 »
Really nice Sonic
Congrats on a great build
+1 on Tom's 102 wiring suggestion for the Switchcrafts
so the NOR input has no ground ?
I'm finishing up a 183 style and it has a ground from the NOR input on the layout just wondering?
same ? as CHIP is asking
Darin
sonicmojo
Post by sonicmojo »
dcribbs1412 wrote: so the NOR input has no ground ?
Darin
I do have ground wires on the ring of both jacks so essentially I am right back to the 3rd gen jack layout. I am using a 183 design board right now and it has a ground wire to it also.
I think my original issue had something to to with my 3rd gen FET board and the jack confusion was brought into the process of it. There's no ground to the FET board on the 2nd/3rd gen layout but is on all the others. I am pretty sure there should a ground there to the trimmer. This may have been my issue with high FET voltages in the first place. I'm going to try it again with the ground in place.
ToneMerc
Post by ToneMerc »
Darin
Ground is there
http://ampgarage.com/forum/files/ods50w ... ic_170.pdf
sonicmojo
Post by sonicmojo »
Yep. What I meant is ground from the FET board is on that schematic but missing from the layouts for 2nd/3rd gen. I was cross-referencing both as I went but missed it at first.
dcribbs1412
Sorry to beat this into the ground
Structo said
What I did was just follow the #102 layout which shows the 14b FET jack and the Normal 12a jack.
Look at the connections carefully, especially the short little jumper on the FET jack on the right side.
does this "short little jumper" apply to the 183 layout also?
Darin
It should be the same for all of them.
Bear in mind that Dumble used the Kobiconn jack, not the Switchcraft shown on the layouts.
dcribbs1412
Thanks Tom
just wanted to make sure
as the "little jumper" is not on the 183 layout or schem
will be adding it ASAP
Thanks for your time
Darin
talbany
Post by talbany »
Tom is right..Keep in mind if you use the switchcraft jacks for fet you need to isolate it from chassis ground w/isolation washers..You can also use the crappy plastic marshall style jacks there as well..I believe the Ceriatone layouts show you how to wire these up if you want to go there..
God Luck!!
Uh oh, I wasn't aware of that Tony.
Why would the FET jack be isolated when it is grounded right to the normal jack?
I think I wired mine like the #124 layout shows.
Mine seems to work ok, although I am currently having a intermittent on the FET jack which I believe is the switches on the jack that need to be tweaked.
dcribbs1412
much appreciated info Tony
Darin
sonicmojo
Post by sonicmojo »
+1, thank you for the extra information. My amp is starting to open up a little after a couple of days. I'll hopefully get a clip posted soon.
dcribbs1412
Great news Sonic....would love to hear it
Did you isolate the FET jack?
I will check local hardware store for some sort of iso washer
or may order the
Kobiconn jack from Mouser I think this is the one
http://www.mouser.com/Search/ProductDet ... 161-0084-E
not trying to over-complicate things but want it to work properly
BTW it seems the jacks are scheduled for end of life at Mouser
Darin
