SSS 002 LAYOUT
Re: SSS 002 LAYOUT
Do you guys want me to make a Sticky post of these in the Files section or do you want to wait until the design is ironed out some more?
The only thing I ask is that we keep the version numbers of the layouts and schematics current so that previous versions can be ignored as we get more data.
vibratoking
Re: SSS 002 LAYOUT
Post by vibratoking »
Tom - I would wait on the sticky until more finalization occurs. That way the sticky will be much more concise. We can put a link to this thread from the sticky so that readers can come here for more details.
talbany
Re: SSS 002 LAYOUT
Post by talbany »
I agree
goodtone77
Re: SSS 002 LAYOUT
Post by goodtone77 »
put me down for the kit list of interest ( chassis, boards etc...) a sss ,when it comes up, will jump to my next project.
toner
Re: SSS 002 LAYOUT
Post by toner »
this may be a dumb question, but how did dumble make those SSS boards? why not use leads to connect the eyelets like fender and the ODS? how was it done in the high plains drifter clone?
boldaslove6789
Re: SSS 002 LAYOUT
Post by boldaslove6789 »
toner wrote:this may be a dumb question, but how did dumble make those SSS boards? why not use leads to connect the eyelets like fender and the ODS? how was it done in the high plains drifter clone?
Dumble made PCB's using Copper Clad PCB Board. G10-Garolite can be used with Eyelets too though.
Aaron
Re: SSS 002 LAYOUT
Post by Aaron »
Revised layout below. Please note this is unverified and has not been tested, yet :D
What I've done is, any values of the components that are different to the hand drawn schem are in blue. The BLUE values in the layout are suggested values that might be corrections to the schem.
I'm not saying this is an exact clone of the original SSS 002. I have only tried to draw up from the information that has been provided.
I haven't seen a full picture of SSS 002 chassis, so the positioning of the power supply is based on the chassis layout of SSS 004.
Thanks,
Aaron
EDIT:- NEW LAYOUT POSTED
AtomCap
re
Post by AtomCap »
big thanks again..
Max
Re: SSS 002 LAYOUT
Post by Max »
Some suggestions:
When the hand drawn schematic of SSS#002 was posted, AFAIR some members here posted that this schematic isn't correct. And AFAIR some of the members here suspecting this argued that this schematic shows some obvious design flaws contradicting what's known about tube amplifier technology. So IMO it might be very helpful if members suspecting this schematic to be full of mistakes might explain why they think so and might point out what they suspect to be wrong, just as markusw e.g. explained why he suspects the 100K LIN volume control to be wrong because the deep switch will not function as usual with a 100K LIN pot in the circuit.
The #002 schematic shows the Fender part numbers of the transformers. So these could perhaps be added in a way similar to the one shown in the layouts in the files section.
Perhaps the members here more familiar with tube amp technology than I am might be able to deduce the V1 - V7 tube compliment from the circuit details? If so, perhaps the tube compliment could be added, too.
On the attached picture of SSS #002 you can see that the yellow Atom filter capacitors have already been replaced by someone when this picture was taken.
Picture source: http://ampgarage.com/forum/viewtopic.ph ... 020#205020
Cheers and a great weekend to all here!
Max
JazzGuitarGimp
Re: SSS 002 LAYOUT
Post by JazzGuitarGimp »
Hello Everyone,
I won't be so bold as to suggest this could be an error, but I'd appreciate any and all comments on this:
I am curious about the voltage across V7 in the SSS #002 schematic. I don't see any reference to tube types in the schematic, so I will assume V7 is either a 12AT7 or a 12AX7 (although 12AU7 might be a reasonable choice). We have +379V on the anodes and -40.4V on the cathodes, which places a whopping 419.4V across the tube! The 12AT7 has a design limit maximum of 300V while the 12AX7 (and 12AU7) have a design limit max of 330V. Can this tube be expected to have a long service life?
Many thanks - this is an invaluable forum!
Lou
Lou Rossi Designs
and Schematic Capture
Aaron
Re: SSS 002 LAYOUT
Post by Aaron »
Revised layout below,
Just a minor tweak to the filter input.
The layout is untested so assume it has errors.
Thanks,
Aaron
Max
Re: SSS 002 LAYOUT
Post by Max »
Steel String Singer clip: http://ampgarage.com/forum/viewtopic.ph ... 208#221208
Max
bcmatt
Re: SSS 002 LAYOUT
Post by bcmatt »
So, how is progress coming on this? Are there particular parts of this last layout that are either quite definitive or highly doubted?
Has anyone tried building one?
I am particularly interested in #002 because I have a young friend that described it as his dream amp after researching tonnes of clips. He most likes John Mayer's SSS, as well as the Bludotone specifically.
It would be great if there was enough confidence in the schem and layout to get get us to the point where we could attempt it.
AtomCap
re
Post by AtomCap »
Aaron can you define the value of the multi can cap?
Aaron
Cap can value
Post by Aaron »
Hi AtomCap,
On the hand drawn schem, the 3 cap values were 20uF. I don't know if all 4 values are the same. The only ones I can get here are 40-20-20-20.
In SSS 002 it doesn't matter cause the fourth cap isn't used, but in SSS 001 it is used.
Does anybody know if the values are all 20uf's or 40-20-20-20uf's.
Thanks,
Aaron
