SSS002 build happiness
hywelg
Re: SSS002 build happiness
Post by hywelg »
Erwin, that sounds stellar. May I ask, do you have heavy gauge strings and a fairly high action? I find that sort of sound is very revealing of even the slightest fret buzz and you had none. Matt Schofield has a similar sound clean, and runs 11's and quite a high action. Very revealing of poor technique, but you'll not be troubled by that!
Richard1001
Post by Richard1001 »
erwin_ve wrote: Fri Jul 31, 2020 9:04 am Thanks Rootz,
It certainly is the best clean amp I ever played, the reverb is very good and enjoyable! It has a bit of a ducking effect, in the decay the verb gets louder!
I might tweak the amp for more bass, even with a 4x12 cab, basically full bass now and I think it can use a bit more.
Talked to Ryan about this and there are 2 spots were the coupling caps can be increased with good results.
Since i am going to build this amp soon (thanks for the great chassis Erwin) i did look at a lot of the scematics and dumble pictures. Regarding the low end: before changing coupling caps, it seems more logical to change the 1uF de-couplingcap to 5uF on the direct signal mixing tube. I noticed you use a 1uF on both mixing stages. On the Japanese schematic there is a 5uF on the reverb side and 1uF on direct, but i think this could be a mistake and should be the other way around. It makes more sense to have a higher roll off frequency for the low end at the reverb mixer, and keep the low end in the direct signal.
erwin_ve
Post by erwin_ve »
hywelg wrote: Tue Aug 04, 2020 7:58 pm Erwin, that sounds stellar. May I ask, do you have heavy gauge strings and a fairly high action? I find that sort of sound is very revealing of even the slightest fret buzz and you had none. Matt Schofield has a similar sound clean, and runs 11's and quite a high action. Very revealing of poor technique, but you'll not be troubled by that!
Thanks Hywel, I run 10's and have a action that keeps the fretbuzz out as much as possible which some consider high action.
I really like voicing and feel of the SSS: you can hear all subtle nuances in dynamics and picking angle differences. It's a great expression tool for sure!
Erwin
erwin_ve
Post by erwin_ve »
Richard1001 wrote: Wed Aug 05, 2020 7:51 pm
Hi Richard, thanks for chiming in! Should be easy to try with some jumpered lytics. I"ll let you know in a while.
Erwin
Colossal
Post by Colossal »
Fantastic looking and sounding amp, Erwin. I don't want to derail, but wondering if you have tried your amp with a guitar with humbuckers? I know most that build these play Strat type guitars. I would love to hear how a Les Paul would sound.
p.s. Love Matt Schofield! He has amazing tone and feel.
erwin_ve
Post by erwin_ve »
Colossal wrote: Thu Aug 06, 2020 9:44 pm Fantastic looking and sounding amp, Erwin. I don't want to derail, but wondering if you have tried your amp with a guitar with humbuckers? I know most that build these play Strat type guitars. I would love to hear how a Les Paul would sound.
Not yet! I was on a 14 day break. I"ll let you know asap, my Les Paul needs some TLC, my 335 is a nice guinea pig:-)
Matt Schofield is great; I was a few years back at a gig, the guy is flawless, the quality of his live performance equals his cd recordings.
Colossal
Post by Colossal »
erwin_ve wrote: Mon Aug 17, 2020 4:02 pm
Hi Erwin,
I hope your break was restful in these trying times. I would very much like to hear your thoughts on how a Les Paul and 335 behave with the SSS. I really like the 102 clean channel with Gain on about 6, TMB all on 5 (straight up), Rock mode, Master on 2-3, and Presence on 6. The SSS is a different beast though with that glassy, clear sound. Those cathode followers do a nice trick.
As for Matt Schofield, he is amongst my favorite modern players. l really love a Strat in certain players' hands, and his tone and playing is killer. I hope to get to see him one of these days.
Dave
talbany
Post by talbany »
Sweet build Erwin for sure :D Congrats!!
IMO When you build an 002 with the pi driver they all to me sound and react pretty much the same.Real CLEAN dynamic touch sensitive extended frequency response the percussive pick attack and plenty of fret buzz, the sound is un-mistakeable. A soft touch is all you really need if you try to muscle it too hard it reaches a point where it just becomes wasted energy and the fret buzz gets louder the amp is so clean and all the compression. Here is mine with a touch of A Tube Screamer. Pretty much the same sound same amp (kt 100'S). The action on this Strat was way too high Please ignore the clams :oops:
BTW.How do you like the reverb in that amp?
https://www.youtube.com/watch?v=qxA8kZtr7cY
erwin_ve
Post by erwin_ve »
A amp isnt finished as long as it isnt in its housing.
I had a head cab made for me by Elfring(Netherlands).
Great and neat looking head shell
The last months tried some reverb tanks from different vendors. Settled with the accutronics one.
Erwin
dorrisant
Post by dorrisant »
Very nice Erwin! Looks beautiful.
rccolgan
Post by rccolgan »
wow beautiful, Erin!
Ryan
https://www.thetonegeek.com/
Vertigo
Post by Vertigo »
erwin_ve wrote: Mon Dec 07, 2020 2:03 pm A amp isnt finished as long as it isnt in its housing.
The last months tried some reverb thanks from different vendors. Settled with the accutronics one.
Erwin
Looks great Erwin!
Good timing too. I just finished mine and need to make the head cab for it. How tall is yours? I've been trying to find information about how much space to leave between the reverb tank and the transformers to keep it quiet.
Sean Chaney
erwin_ve
Post by erwin_ve »
Vertigo wrote: Mon Dec 07, 2020 4:24 pm
Erwin
Looks great Erwin!
thnx! Mine is 305mm (outer dimension)
Vertigo
Post by Vertigo »
erwin_ve wrote: Mon Dec 07, 2020 5:09 pm
Thank you!
Sean Chaney
timrobertson100
Post by timrobertson100 »
Hi Erwin
Can you please tell me what that 3k3 resistor is that you have on your cap can? It doesn't appear on any of Ryan's work unless I miss something, and the photo you have of it doesn't show where it's connecting.
