Rocket Documents
- Ron Worley
Re: Rocket Documents
That would be "amps" plural, and I am not a liberty to post said information, as I am under an gentleman's agreement not to do so.
I'd say "Trust me", but you seem aggressive enough to not believe me. Your choice.
Ron
Ron
"Aggressive", Ron? C'mon. I think I'm being pretty reasonable in asking for the name of the amp, its tube complement, and voltages. If you have a "gentleman's agreement not to publish gut shots, that's fine. Everything else should certainly be good to go.
Until I see otherwise, I'll remain skeptical (not to be confused with "aggressive") that we have a real "document" regarding the power supply of a Rocket.
Thank you for your contributions.
Is the wiring of the EQ section correct in the schematic?
Have a good evening
Trace
Have a good evening
Trace
Zippy, I can tell you without any hesitation that the drawing at the beginning of the thread is correctly laid out. That goes for the power section too. I helped Ron and Dr Hulsey with any technical questions they had regarding the Rocket. I have seen two "actual" Rockets gutshots and not just one each! I have had access to full pictures of the Rockets and discussed in detail each componet and source with the owners. I still have access to them. I cannot post any pics as I was asked not to. I will however, be finished with a replica that I will post pictures of and then you will have your pics. This is authentic down to the perf board and layout. In the past I have been "in" many Trainwrecks whether it is by picture or by my own hands. I then made copies of the amps and posted pictures. The pictures of my amps that I have posted are not just to show off every amp I've built rather, it is a surregate "gutshot" of the amp I copied. This way I don't violate any confidence and the community gets to "see" the inside of what a "real" wreck looks like.Zippy wrote:"Aggressive", Ron? C'mon. I think I'm being pretty reasonable in asking for the name of the amp, its tube complement, and voltages. If you have a "gentleman's agreement not to publish gut shots, that's fine. Everything else should certainly be good to go.
Thanks for filling in the blanks, Allyn.
Whohoo, that's the spirit, Allyn!
- Voodoo_Man
Thanks for the nice work Mr. Worley and Mr. Hulsey.Ron Worley wrote:Hey Wreck fans... Some more interesting technical data thanks to the digital wizardry of Tim Hulsey. We worked hard over the weekend to get the drawings right.
Ron Worley and Tim Hulsey (DrHulsey)
God Bless,
John
Rocket ps turret board version for large caps
I have not built this check for errors. This is for those large Sprague caps.
dave
dave
Instructions...I don't need no stinkin instructions
Here's an alternate version for smaller p/s caps; Xicon, Nichicon, F&T, etc.
Rocket A0 fuse location
I believe the A.C. fuse should be on the "hot" side of the transformer , not on the white "neutral" . If the fuse blows , you could still have 120VAC to ground and get zapped playing around in there .
Macshaft:)
- Ron Worley
Here's the Rocket's Voltage Chart for use in initial power up.
- skyboltone
How about a filled in voltage chart, or voltages on the scheme?Ron Worley wrote:Here's the Rocket's Voltage Chart for use in initial power up.
- Ron Worley
Dan-
I haven't finished my LP yet, so I have nothing, same for the Rocket....
But I figured that this should be helpful nonetheless..
Ron
Ron
Has anyone noticed this discrepancy between the layout and the schematic, or am I looking at the wrong version of something?
Schematic:
V4 > R19
V5 > R20
V6 > R21
V7 > R22
On the layout the values are reversed:
V4 > R22
V5 > R21
V6 > R20
V7 > R19
Dave
Schematic:
V4 > R19
V5 > R20
V6 > R21
V7 > R22
V4 > R22
V5 > R21
V6 > R20
V7 > R19
Dave
- Ron Worley
Obviously, it's electrically immaterial, but I will check it out and correct if it's backward..... it very likely that you are right!!
Ron
