Any one been inside a Komet 19 yet?
FYL
Re: Any one been inside a Komet 19 yet?
Post by FYL »
Or the Songwriter 30 which seems to me is a Constellation.
Constellation: two differently voiced preamps, one using a 6SN7GT, the other a 12AX7, hi-cut crossline + bright switch, std 12AX7 PI
Songwriter 30: one single 12AX7-based preamp, 6SL7GT probably used in the PI
Cliff Schecht
Post by Cliff Schecht »
That's one lucky 12AX7.. :lol:
Cliff Schecht - Circuit P.I.
amplifiednation
Post by amplifiednation »
anyone gonna try to build this amp? I have the wreck bug. i'm gonna skip the liverpool, but was thinking about a Komet. I don't need another 50+ watter and this P2P looks like a challenge I'm up for.
I'm sure someone is going to tell me to use the search feature...but do we have any good info on the 19?
I hear there might be a schematic of the 60 somewhere but I wouldn't know where to find it (extreme sarcasm implied)
Amplified Nation
www.amplifiednation.com
@ampnation
The resistors are wrapped and the caps wiped clean no markings so you would have to measure a Komet 19 to be able to clone it.
However, you could build your own version of the circuit as there are no mysteries inside the amp just some values used are covered up.
I think there are many other amps that could be built then this one such as the 18w lite Marshall is a great amp.
wsaraceni
Post by wsaraceni »
M Fowler wrote:The resistors are wrapped and the caps wiped clean no markings so you would have to measure a Komet 19 to be able to clone it.
i had my 18watt lite, another 18 watt, and a komet 19 at the same time and the komet 19 blew the other two away. similar, but the komet 19 was a lot better. ultimately i kept my 18 watt lite (which i am rebuilding) and sold the k19 for a strat. but miss it sometimes
Colossal
Post by Colossal »
wsaraceni wrote:i had my 18watt lite, another 18 watt, and a komet 19 at the same time and the komet 19 blew the other two away. similar, but the komet 19 was a lot better. ultimately i kept my 18 watt lite (which i am rebuilding) and sold the k19 for a strat. but miss it sometimes
Did you take any voltage or component measurements in the K19? What features of the tone did you feel made the amp sound better than the 18W Lite?
wsaraceni
Post by wsaraceni »
didnt take any measurements. just peeked inside. main difference was that it sounded a lot bigger. my lite had really bad transfomers since i built it in a blues jr chassis and re-used that iron, but even the full 18 watt i tried sounded small in comparison. as did the at mars specialist i had around the same time. the k19 just sounds bigger. also, the saturation knob was really useful i thought. wish i knew what it was and how to properly add it to my 18 watt lite iib.
Colossal
Post by Colossal »
wsaraceni wrote:didnt take any measurements. just peeked inside. main difference was that it sounded a lot bigger. my lite had really bad transfomers since i built it in a blues jr chassis and re-used that iron, but even the full 18 watt i tried sounded small in comparison. as did the at mars specialist i had around the same time. the k19 just sounds bigger. also, the saturation knob was really useful i thought. wish i knew what it was and how to properly add it to my 18 watt lite iib.
Yes, the poor quality Blues Jr. iron probably had a lot to do with the sub-par tone on your Lite. I am reasonably certain the Saturation control is a variable grid leak, similar to varying the 150k grid leak resistor on the Express or Liverpool (I could be wrong about that however). Basically a gain control.
wsaraceni
Post by wsaraceni »
definitely could be part of it. but the 18 watt i tried had top of the line parts in it and the k19 was still bigger than that.
Vince
Post by Vince »
guitarpkr76
Post by guitarpkr76 »
Has anyone been able to dig into the 19 a little more?
Vince
More K19
Post by Vince »
Stolen from lespaulforum.
Vince
Re: More K19
Post by Vince »
Vince wrote:Stolen from lespaulforum.
I have two more, not displaying on this forum :(
There have been some that delved into this amp but I'm not so sure it would be worth cloning.
TUBEDUDE
Post by TUBEDUDE »
Can't wait for the Tone King Metropolitan to go out of production. I want that schematic bad :D
