superlead with master volume redplates
hitchcaster
Re: superlead with master volume redplates
Post by hitchcaster »
i was gonna say leaky coupling cap or bad tube but it looks like you've replaced those right?
hitchcaster
lastcaress83
Post by lastcaress83 »
Thanks Ian, that explains a lot.
Yeah hitch, I already try the coupling caps and they didn't help at all.
Do you guys think that putting a big resistor (say 10 watt, 1k) between the B+ supply and the choke would at least tame down the screen voltage to the tubes enough that they wouldn't red plate anymore?
I had a tech recommend this to me but I've got reservations about altering the stock circuit. Any opinions on this? Will it kill my tone?
Ian444
Post by Ian444 »
Sounds like a good idea to me. Try it!
finn648
Post by finn648 »
Hi lastcaress83,
Randall Aiken has an interesting discussion on his aikenamps.com site regarding lowering B+ using zeners and mosfets.A little more sophisticated than an high power resistor.Located in his tech notes section IIRC. ..finn
Roe
Post by Roe »
A couple of clip from the amp that previously had problems with redplating:
http://snotpope.com/downloads/Superskur ... ddrone.mp3 (slide/left channel)
http://snotpope.com/downloads/Superskur ... skurk2.mp3
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
