Agreed, I know "Dumble" is a trademark. "Overdrive Special" also?
Erwin
I use a vinyl cutter to make a stencil. Then brush on clear coat to prevent bleeding, once dry I roll on white or black enamel for pinstriping, 2 coats and let dry between. Does a nice job as long as you don't go too small with the font.VolkerStaub wrote: ↑Mon Oct 16, 2023 10:49 pm "Overdrive Special" is not a registered trademark - theoretically you could've printed it on the chassis.
Anyways, what would be a proper way to do it myself? These decals at Amazon probably will fall of quick after some time. Any hints?
Hi Volker,VolkerStaub wrote: ↑Sat Oct 28, 2023 12:10 am Great stuff Erwin! Would love to hear a demo if you're willing to record some.
Also curious what transformers you used?
Thanks! The snakeskin combo used to be the housing for my 2nd gen hybrid, that amp is in a headshell now.
Thanks Dan,
I made a small test track, clean and lead gtr are all the 2nd gen amp.VolkerStaub wrote: ↑Sat Oct 28, 2023 12:10 am Great stuff Erwin! Would love to hear a demo if you're willing to record some.
