I'm currently on vacation and can not have a look inside the amp, but have looked at my photos of it and I think those Orange Drop 6PS series 600 V from TT should be ok, and also those 1/2 W RN65D resistors. But I wonder what kind of resistor that one on the bass pot is, also the precence cap? I can not figure it out from these photos.
OTS #102 to #060 (without reverb)?
Re: OTS #102 to #060 (without reverb)?
I’m not an expert but it looks likely to be a carbon film resistor to me. The TT xicon resistors are good quality. For the 1uF I’d opt for the standard TT electrolytic. Alpha’s are decent pots.
If you look at the AN gutshot, you can see where he is putting the RN65s (e.g. plates) and where he’s using the carbon films. Might it be worth copying that, as a starting point?
Thank you. Yes that resistor on the bass pot is a carbon film resistor. Thanks for suggesting the TT xicon.timrobertson100 wrote: ↑Sun Mar 10, 2024 6:15 pm I’m not an expert but it looks likely to be a carbon film resistor to me. The TT xicon resistors are good quality. For the 1uF I’d opt for the standard TT electrolytic. Alpha’s are decent pots.
The 2.2 uF are "Holy grail" branded, rated at 25 V, so will try a standard 1 uF TT electrolytic as you suggest. Like this one? https://www.tube-town.net/ttstore/en/el ... 100-v.html or this https://www.tube-town.net/ttstore/en/ma ... axial.html ?
2.2uF is what is the #102. Very distinct especially in the mid range. 1uF is more affecting the high tones and is in #124, #183 etc.ynor wrote: ↑Mon Mar 11, 2024 12:46 pmThank you. Yes that resistor on the bass pot is a carbon film resistor. Thanks for suggesting the TT xicon.timrobertson100 wrote: ↑Sun Mar 10, 2024 6:15 pm I’m not an expert but it looks likely to be a carbon film resistor to me. The TT xicon resistors are good quality. For the 1uF I’d opt for the standard TT electrolytic. Alpha’s are decent pots.
Yes, mine is a slightly modded #102. I want to try the classic tone stack and maybe also low-plate in this amp, so I'm looking to replace the 2.2 with a 1uF. Is there any significant differences between the two menioned above (TT 1uF 100V or Mallory 1uF 63V)?erwin_ve wrote: ↑Mon Mar 11, 2024 2:22 pm2.2uF is what is the #102. Very distinct especially in the mid range. 1uF is more affecting the high tones and is in #124, #183 etc.ynor wrote: ↑Mon Mar 11, 2024 12:46 pmThank you. Yes that resistor on the bass pot is a carbon film resistor. Thanks for suggesting the TT xicon.timrobertson100 wrote: ↑Sun Mar 10, 2024 6:15 pm I’m not an expert but it looks likely to be a carbon film resistor to me. The TT xicon resistors are good quality. For the 1uF I’d opt for the standard TT electrolytic. Alpha’s are decent pots.
- ijedouglas
That is difficult to answer and the only way to know would be to try both and see which one you like.
Ian
- erwin_ve
And maybe try a tantalum too?ijedouglas wrote: ↑Mon Mar 11, 2024 2:47 pmThat is difficult to answer and the only way to know would be to try both and see which one you like.
