I wouldn’t think so, and reports from others seem to agree. I assume you are aware of the associated resistor value changes in the bias circuit and driver cathodes, and see this post about the eyelet board version in the files section where a small resistance is added to the AC input, and a bleeder resistor is added to the positive side: https://ampgarage.com/forum/viewtopic.p ... 23#p463923GAStan wrote: ↑Thu May 23, 2024 4:41 am Completed installation of bipolar power supply. Amp is now working again with better B+ and other voltages.
Question: with the decreased voltage the bipolar supply provides V7 does this limit the clean headroom? Volume? Is there a noticeable tonal difference between the original and bipolar supplies?
A SSS Build
Re: A SSS Build
Re: A SSS Build
Congrats Glenn - they are fabulous amps, right?
In the coming months, I'll get to building a second one, using the parts bundle I bought from a TAG member here. Can you please post pics of your bipolar supply setup?
Re: A SSS Build
I did see that post after I had the bipolar installed. The 33R was added to the bias tap but not the 330k bleeder because I haven't found a suitable place to install it. I may put one on the PI board but I am very wary of the charged caps in the meantime. The divider resistors were also changed. The resistor in series with the pot is 10k because the pot is actually 25k, originally a 10k that I transplanted a 25k element into. Lacking 75k I used a 68k (measures 69k7).martin manning wrote: ↑Thu May 23, 2024 7:56 amI wouldn’t think so, and reports from others seem to agree. I assume you are aware of the associated resistor value changes in the bias circuit and driver cathodes, and see this post about the eyelet board version in the files section where a small resistance is added to the AC input, and a bleeder resistor is added to the positive side: https://ampgarage.com/forum/viewtopic.p ... 23#p463923GAStan wrote: ↑Thu May 23, 2024 4:41 am Completed installation of bipolar power supply. Amp is now working again with better B+ and other voltages.
Note the 33R resistor in black heat shrink on the bias tap input to the board.timrobertson100 wrote: ↑Thu May 23, 2024 12:44 pm Congrats Glenn - they are fabulous amps, right?
If using Erwin's chassis be aware of the close proximity of the PT and end wall of the chassis, makes for a tight fit depending on where you plan to mount the board.
It's a pretty straightforward install but pay attention to Martin's comments above.
Let me know if you need more detailed pics and I'm happy to get them for you. The cabinet for this won't be delivered for another month or two so it's no trouble to click and post pics in the meantime.
Glenn
I solder better than I play.
Re: A SSS Build
I've been working on an oscillation. It's only in the power section, from the PI to speakers. Goes away if feedback from speaker is disconnected.
First three of the below are
Channel 1: 8 ohm dummy load;
Channel 2: PI (V6) Pin 6.
400 hz signal.
8 ohm dummy load.
Refer to Viperdoc's schematic.
Pic 1
This is how I originally had it phased, wired according to wire color of OT. Note the voltage levels, 30 volts into 8 ohms. Extreme clipping, looks like a squarewave. 44hz. Amp was buzzing, I believe this is what caused the possible damage to the original PT. I only had the feedback connected long enough to save this on my o'scope.
Pic 2
Same phasing as above but Feedback from 4 ohm speaker tap disconnected. Signals out of phase. If I understand correctly this should be correct phasing for negative feedback.
Pic 3
Here I have reversed wires from CF (V7) to power tubes. No feedback. Signals in phase.
Pic 4
Same phasing as Pic 3. No signal in, volumes on zero. Channel 1 is 60hz noise, I am literally simply touching the probe tip to my finger just to get a 60hz trigger. Channel 2 is PI pin 7. WITH Feedback. Higher frequency varies between 100Khz and 150Khz. I added 220k gridstoppers to CF, it only decreased the frequency from 150Khz range to 100Khz range.
I'm unsure which phasing is really correct, picture 2 or 3 above?
400 hz signal.
8 ohm dummy load.
Pic 1
Pic 2
Pic 3
Pic 4
Glenn
Re: A SSS Build
Found a problem. Hopefully the problem. Circled 270k should be 270r. Voltages on V6 are much higher than on Viperdoc's schematic. Will work on this more tomorrow.
Glenn
Re: A SSS Build
Hope that solves it!
The speaker output should be in phase with the PI input.
Yours will be the first with the new resistors added to the bipolar supply. I’ll be interested to hear how that works in hardware.
Re: A SSS Build
It did fix the problem, thanks.martin manning wrote: ↑Fri May 24, 2024 3:54 pm Hope that solves it!
The bleeder is definitely a good idea. The +170 volt caps were still at 50vdc after sitting overnight before I added it. Next time I power it up I'll get voltages and post them.
Glenn
Re: A SSS Build
Thanks for the heads up, I'll check it out.martin manning wrote: ↑Sun May 26, 2024 4:33 pmI made a small tweak to the eyelet board .pdf on this. Increased the current limiter to 47R, and decreased the bleeder to 150k. Should have it drained in a minute or so.
Glenn
Re: A SSS Build
I'm having a cabinet built for this project and have a question. How much space should there be between the bottom of the PT and top of the Reverb tank?
Glenn
Re: A SSS Build
I would start with the proportions from the real thing to get the height of the box, and do an experiment by stacking the chassis and tank up on the bench to see if there is any problem. Keep the output side of the tank close to the input side of the box since it is most sensitive to picking up hum.
http://www.jimsguitars.com/s/3888/Ampli ... Singer.htm
Last edited by martin manning on Mon Jun 17, 2024 12:26 pm, edited 1 time in total.
Re: A SSS Build
I'm fairly certain the real deal is 11.5" wood-to-wood height as a starting point for ya. That's what I used with mine and the proportions look good and no reverb hum or oscillations.
Ryan
https://www.thetonegeek.com/
