#102 Build started
Re: #102 Build started
If you are running 12V relay supply, that relay should work.
For the FET input jack, Switchcraft type 13E .
2N4416A is an equivalent JFET.
Ang3lus
Post by Ang3lus »
some progress has been made:
Ang3lus
Post by Ang3lus »
2:
Ang3lus
Post by Ang3lus »
3:
Ang3lus
Post by Ang3lus »
4:
Ang3lus
Post by Ang3lus »
will this jack be good for a FET input ?
Ang3lus
Post by Ang3lus »
some more work done today, will probably close shop for the next 2 weeks till i have some more time.
Ang3lus
Post by Ang3lus »
2:
Ang3lus
Post by Ang3lus »
3:
erwin_ve
Post by erwin_ve »
Angelus; Nice pics of your progess. One detail thing: I don't know what you used to draw the wire layout on the signal board, make sure you wipe it out. Some materials(like pencils) have conductive characteristics.
Ang3lus
Post by Ang3lus »
thanks for the advice, i will check continuity with my meter
Ang3lus
Post by Ang3lus »
almost finished with the pre-amp
Ang3lus
Post by Ang3lus »
2:
Ang3lus
1:
Post by Ang3lus »
1:
Ang3lus
2:
Post by Ang3lus »
2:
