Dumbleland update (was SSS) :D
Max
Re: Dumbleland update (was SSS) :D
Post by Max »
David Root wrote:Would you share those "150W SSS datasheets" with us?
Hi David,
here's a word by word copy of the one I have:
data sheet
Dumble
Amplifiers
"Steel String Singer"
The "Steel String Singer" is designed to deliver the guitar sound necessary to fill stadiums and large halls. The power ability and tone circuitry work together to produce volume and tone of very exiting dimensions. The amplifier provides the player with a huge, clean sound that is enriched with a warm, singing quality.
SPECIFICATIONS
Power Output: 150 watts of true power
Dimensions: 12"H x 28.25"W x 10.5"D
Weight: 80 pounds (head only)
Power Requirements: 120VAC, 60Herz, & 540VA at full output
Output Impedance: 4 ohms and 8 ohms switchable
Input Impedance: NOR = 1M ohm, and FET = 3.3M ohms
TUBE COMPLIMENT
4 x 7025 high-mu twin triodes
1 x 5751 high-mu twin triode
4 x 6550A beam power tubes
CONTROLS AND EQ SWITCHES
Preamp Controls: volume, treble, middle, and bass
Preamp Switches: bright, deep, rock/jazz, hi step filter & low step filter
Reverb Controls: send, and return levels
Master Section: master volume, and presence
SIGNAL CONNECTIONS
Inputs: NOR, and FET
Access ports: preamp out and power amp input (2.5V, 500K ohms)
Outputs: main speaker, and extension speaker
POWER SWITCHES
A.C. mains on/off
A.C. mains grounding
Operate/standby
REMOTE SWITCHING
preamp boost on/off
reverb on/off
Max
boldaslove6789
Post by boldaslove6789 »
Thanks Max w/ the fax!!
Max
Post by Max »
Dumble Data Sheet
"DUMBLE LAND 300SL"
SPECIFICATIONS
Power Output: 300 watts true power
Output Impedance: 2 or 4 ohms
TUBE COMPLIMENT
2 x 7025 high-mu twin triodes
1 X 12AU7
2 x 12BH7
6 x 6550A beam power tubes
Preamp Switches: bright, deep, rock/jazz, and preamp boost [Max: PB = rock/jazz middle position]
Filters: Hi and Low step filter
Reverb Controls: Send, and return levels
SIGNAL CONNECTIONS
Access Ports: preamp out, and power amp input (2.5V, 500k ohms)
POWER SWITCHES
A.C. mains on/off
operate/standby
ADJUSTMENTS
Bias Adjust
REMOTE SWITCHING
Reverb on/off
source: http://web.archive.org/web/200801210049 ... 300sl.html
AFAIR this data sheet is consistent with what I remember to have seen in one of these amps.
Max
David Root
Post by David Root »
Thank you Max.
jlatrace
SSS choke spec help
Post by jlatrace »
I need some help. I have looked everywhere and cannot find the specs for a filter choke for a 150W SSS. Closest I get is the Sunn schematic that shows two Sunn 3-10 chokes in parallel.. Any suggestions?
67plexi
Post by 67plexi »
Most high power tube amps used a 4 Henry choke Quad KT88 or 6550A
Fender used a 4 Henry 90mA in the 200 watt and 400 watt amps. I think that's on the weak side.
I'm starting out with a 5 Henry 150mA. The transformers that Dumble cannibalized for the
150 watt SSS did not use a choke.
Good luck, Steve.
Roe
Post by Roe »
I'd guess 3-5H, ca 150mA (for KT88s)
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
jlatrace
Post by jlatrace »
67plexi wrote:Most high power tube amps used a 4 Henry choke Quad KT88 or 6550A
Good luck, Steve.
Thanks!
jlatrace
Post by jlatrace »
Roe wrote:I'd guess 3-5H, ca 150mA (for KT88s)
Thanks!
Bombacaototal
Post by Bombacaototal »
deleted
