Follow-Up on Packard Bell Hum Problem
JacobsNova
Post by JacobsNova »
My previous thread..
http://ampgarage.com/forum/viewtopic.ph ... hlight=hum
I have done a couple of things to try and fix this hum problem. #1 I took out my input selector switch and I took out the hum balance pot so everything is original to specifications. The next thing I did I went to the geofex.com webpage and followed his tutorials on tracing down hum and the tutorial on checking the power transformer because one of the possible causes of hum is a leaky transformer. The transformer checks out okay. By the tutorial I am reading the only thing that might be the problem is that a bias supply with excessive ripple injects hum directly into the grids of the output tubes. So I did what he said and added another capacitor but the hum is still there. I'm just wondering if this is still a problem because if I ground my grids at all the output tubes pin 1 and 2 the hum goes away. I'm just wondering what I should do next. Any help is appreciated...
Re: Follow-Up on Packard Bell Hum Problem
Do you have the cathode of V1 wired directly to the ground of the input jack, this reduces the first gain stage hum in PTP builds.
20to20
Post by 20to20 »
Your factory diagram specifies a 5U4 but the hand drawn PS shows a 5Y3 and a 300R resistor ahead of the first filter. Are you still working with a 5Y3 and the modified input components? Your 5Y3 is only good for half the current of a 5U4.
20to20
Post by 20to20 »
Any progress?
drz400
Post by drz400 »
JacobsNova wrote:My previous thread..
You can inject hum directly into the OT if they are not T and are too close. Since they have no end bells I would try and turn them 90 degrees to see what happens
20to20
Post by 20to20 »
Any Progress??
