Bluesmaster pre with non-hrm overdrive
erwin_ve
Post by erwin_ve »
Hi,
This week a friend of mine is gonne bring over his d-clone.
Non-hrm skyline(sorry I'm not into the new namings).
The plan is I'm gonna mod it to a Bluesmaster pre-amp with a non-hrm overdrive section and standard PI/power amp with 6L6.
Obviously it will take some time to get things right, but I like the experiment very much.
Is there anyone who invented the wheel with this? I appreciate if someone could share their experience with this particular built.
chris_sanford
Re: Bluesmater pre with non-hrm overdrive
Post by chris_sanford »
erwin_ve wrote:Hi,
I've tried that, and I like it quite a bit more that the straight-up BM circuit.. though I'm not sure if it's worth the trouble (if you already have a non-hrm skyline amp). I prefer the mid-range boost of the normal PAB circuit, and that kinda works with the BM pre by just lifting the treble pot/bass pot junction instead of the tail of the entire stack, however due to the low-value slope resistor you'll find that the mid and bass controls still work when you do this. Anyway, I suggest that you experiment with it, and let us know what works out best for you!
chris
glasman
Re: Bluesmaster pre with non-hrm overdrive
Post by glasman »
I did something similar on one amp (Chris actually played it). Chris it was that snakeskin amp. At that time, the amp had 5881's installed.
It was a Bluesmaster front end into a non-HRM OD section with 150K/100K plates. It actually sounded quite nice.
No loop on V1B btw. Standard BM boost, with gain reduction to 6db.
Gary
About 5 miles south of I-94
www.glaswerks.com
erwin_ve
Post by erwin_ve »
Chris and Gary;
Thanks for your input.
Od plates 150k/100k; did you use 5uF cathode cap?
Gain reduction PAB 6dB: instead of the 22M from mid cap you use somewhere between 68-100K?
Erwin
odourboy
Post by odourboy »
Erwin
IIRC, Mark found 72K gave him 6dB boost.
Steven_nl
Post by Steven_nl »
Sounds interesting
erwin_ve
Post by erwin_ve »
odourboy wrote: IIRC, Mark found 72K gave him 6dB boost.
Thanks!
erwin_ve
Post by erwin_ve »
Steven_nl wrote:Sounds interesting
Interesting because it's your amp :D
chris_sanford
glasman wrote:I did something similar on one amp (Chris actually played it). Chris it was that snakeskin amp. At that time, the amp had 5881's installed.
Gary
Gary's amp was killer. I almost went home with it. Thought there was some other secret sauce inside though. Gary? Was the PI normal, or AB(y)normal? :)
chris
erwin_ve
Post by erwin_ve »
First tests sound promising.
Slope 68k, 47k was too bassy.
Mid pot 25k. 0.02uF from V1B.
I left the Nonhrm side with high plates, 330pF snubbers, 180K resistor coming from v2B coupling cap. Standard PI.
Dumblelator in the loop.
A little recording is added.
gilgalad101
Post by gilgalad101 »
Wow, that sounds pretty good. I can't wait to finally get started on my BM. Hopefully it'll happen over Christmas break. I may have to try a non HRM overdrive on mine also.
erwin_ve
Post by erwin_ve »
@gilgalad; thnx!
I'm really loving this amp! Bluesmaster clean has a slightly more compressed feel (compared to Skyline EQ with 150k slope). The tonestack is more responsive than Skyliner for my taste.
And last but not least; the non-hrm overdrive feels and plays like other Non-hrm amps I have. Tone is little different of course.
Really best of both worlds.
This amp has to go back to it's owner so I'm planning to do the same conversion on my HRM amp.
For use with or without a dumblelator there is a push-pull 68pF cap on the master.
PAB is standard Bluesmaster with a 75k from mid pot to ground.
If anyone is interested I can make a schematic.
exocet
Post by exocet »
That sounds very nice indeed.
Was the bright cap engaged here on either clean or OD? If sounded to me like it was on the clean?
erwin_ve wrote:@gilgalad; thnx!
erwin_ve
Post by erwin_ve »
exocet wrote:That sounds very nice indeed.
Thnx Exocet; bright cap on master was engaged on both clean and OD. There was a dumblelator in the loop.
andyhardy
Post by andyhardy »
Sounds really nice.
Schematic would great.
Cheers
