AC "convenience" jack...where can I get one
pula58
Post by pula58 »
Been thinking of designing-in an AC convenience jack for my next build. I like 'em because I can plug my effects power supply into one if there is only one outlet for me (and I have forgotten an extension cord with multi outputs).
Where can I get one?
Kazooman
Re: AC "convenience" jack...where can I get one
Post by Kazooman »
I thought that it would be easy to find one, but I was wrong.
I did manage to find just what you are looking for at McMaster-Carr. It is their part number 8036K5. A receptacle made to mount in a round chassis hole with two flanges for screws.
Sounds great, right? Well, the price is $19.77 each. So much for convenience!
There has to be a source for these things at a reasonable price somewhere.
Phil_S
Post by Phil_S »
I'm not a licensed electrician, so it's not obvious to me what could be wrong about using one of these: http://www.grainger.com/Grainger/LEVITO ... Pid=search comes in white, ivory, and brown! It does gobble up quite a bit of real estate.
This one appears to be more compact, but can't be sure: http://www.automationdirect.com/adc/Sho ... vices/5251
How about something like this?
http://parts.digikey.com/1/parts/100137 ... x2-01.html
I googled "chassis mount AC receptacle".
ampgeek
Post by ampgeek »
Mouser carries many different styles.
Check here for starters.
http://www.mouser.com/catalog/catalogUSD/644/1244.pdf
Good luck,
Dave O.
ampgeek
Post by ampgeek »
I have used example "H" with success in a number of my builds.
http://www.mouser.com/Catalog/catalogusd/644/1245.pdf
Hit the "Next" and "Previous" buttons for other examples that might work for you.
Dave O.
pula58
Post by pula58 »
thanks folks, much obliged!
P.
Phil_S
Post by Phil_S »
ampgeek wrote:I have used example "H" with success in a number of my builds.
Dave O.
Type I looks like it kills two birds in one hole! It says snap in mount, solder tab! At the bottom, type E is only 70¢!
Weber also sells those square auxillary power plugs.
https://taweber.powweb.com/store/cableord.htm
Mojo has square plug also http://www.mojotone.com/amp-parts/Plugs ... le-AC-Plug
Mojo also sells the Amphenol AC receptacle
http://www.mojotone.com/store?search=amphenol
rdjones
Post by rdjones »
M Fowler wrote:Mojo also sells the Amphenol AC receptacle
The round Fender style Amphenol outlet must have gone obsolete.
Mojo's price is steep and "currently unavailable".
I need (at least) one for a Fender rebuild.
[img:600:418]http://www.mojotone.com/Fender-Backpane ... -image.jpg[/img]
rd
rdjones
Post by rdjones »
Structo wrote:How about something like this?
Thanks.
I need to replace the outlet on my Sencore PR57 and that looks like it.
rd
rd
Steve, EDIT no longer available from cooper either I will ask the local cooper sales guy tomorrow.
http://www.newark.com/cooper-interconne ... dp/39F1230
Bob Simpson
Post by Bob Simpson »
I have some of those NOS.
3 prong.
Marked:
Amphenol
Chicago, U.S.A.
15A 125V
How many would you need?
Bob
Please understand that IMO an answer to this question is of no practical relevance at all. - Max
Bob it looks rdjones is in need of those.
This is what is appears everyone has switched to in the industry and doesn't work well for us amp restorers.
Bob Simpson
yuck.
Maybe I should keep them... :D
Bob
