small vs large fuses ??
pula58
Post by pula58 »
I found a neat little AC power receptacle with built-in fuse drawer. The fuse size is 20mm x 5mm...Quite a bit smaller than the size of fuse you'd find in a blackface Fender, for example.
Are these small fuses just as good/reliable/robust as the large ones?
Milkmansound
Re: small vs large fuses ??
Post by Milkmansound »
just make sure you can find a slo-blo in that size. Shouldn't be a problem
Phil_S
Post by Phil_S »
I find the 20mm fuses cost more!
wsaraceni
Post by wsaraceni »
i was just at radio shack. they have slo and fast fuses of all different values needed in that size.
pula58
Post by pula58 »
Phil_S wrote:I find the 20mm fuses cost more!
I was looking online at Mouser, and those fuses costs around $7. I couldn't believe they are so expensive!
wsaraceni
Post by wsaraceni »
hoffman has them $1 a piece
guitarmike2107
Post by guitarmike2107 »
20mm x 5mm is used in the uk all the time, sorry that doesnt help those on the state side.
Mike
katopan
Post by katopan »
Same in Aust. Standard fair and in all of my amps.
Aurora
Post by Aurora »
20x5mm are often referred to as Euro size, and the 1-1/4" as being US size....
diagrammatiks
Post by diagrammatiks »
radioshack and home depot have littelfuses they are less then a dollar, usually 4 for 2 or 3.
pretty common things now a days.
