A Marshall AFD Sqealing problem (video included)
yalesmith
Post by yalesmith »
I built a ceriatone AFD 50 and it is a great amp, more scooped than i would have imagined but it is squealing a bit when I turn up the gain or volume...take a look at the video and i am open to any suggestions
http://www.youtube.com/watch?v=0HMmGK1O ... e=youtu.be
roberto
Re: A Marshall AFD Sqealing problem (video included)
Post by roberto »
Something is creating positive feedback inside the amp.
It's your build or you receipt it already mounted?
ampgeek
Post by ampgeek »
Brand new build? Does the squeal change significantly when you adjust the presence pot?
That sounds a lot like crossing up the OT primary leads on the output tube plates.
Try lifting the NFB lead from the impedance selector. If that fixes it, you will need to switch the OT primary leads on the output tubes.
Good luck!
Dave O.
roberto
Post by roberto »
If that's the problem, just switch the outputs from the PI to power tubes, it's easier.
yalesmith
Post by yalesmith »
yes it is a brand new build and the presence pot really does not affect the squeal but rather acts like a second master volume, which is a bit annoying....as far the primary's on the ot being switch, i wish it was that easy but that's definitely not it.
here is the design if anyone is interested
http://www.ceriatone.com/images/layoutP ... 35_50W.jpg
roberto
Post by roberto »
The problem is not the layout, but how you built it.
We need picture of what you have done.
husky
Post by husky »
roberto wrote:The problem is not the layout, but how you built it.
Agree, sounds like major ground issues as well
Need a gut shot to help you.
______
John Suhr
www.suhr.com
yalesmith
Post by yalesmith »
Here is are a few pics....and again thanks for the help!
Are the wipers of the each of those three trimmer pots wired to the 3rd leg?
In your amp the wipers looks like they are bare not connected to anything?
husky
Post by husky »
yalesmith wrote:Here is are a few pics....and again thanks for the help!
First thing I would do is correct the lead dress to the master volume
Those wires for that type of master are extremely sensitive and IMO should be shielded. I would actually disconnect the master completely (add the bias dividers) and try it without it.
______
John Suhr
www.suhr.com
yalesmith
Post by yalesmith »
Do you mean the PPIV master volume and when you mention "disconnect the master completely (add the bias dividers) and try it without it" - i am loss in what you mean.
thanks!
That end of coax going from the master to the return jack looks suspicious
at the jack. (M)
Be sure to trim the shield back from the center or it will short to ground.
Try swapping X and Y with each other.
Does it squeal inside a shielded head cab?
Dai H.
Post by Dai H. »
note that in the video the open side of the chassis is facing the spk. cab (i.e. right on top of it)
ToneMerc
Post by ToneMerc »
M Fowler wrote:Are the wipers of the each of those three trimmer pots wired to the 3rd leg?
Ditto, those three 10k trimmer are wired as fixed resistors. The wipers should be connected so that they become variable.
TM
I think he has the wipers connected to the resistors and caps sitting behind the trimmers.
