AC15 build started
Vox and Hiwatt Discussion
lego4040
AC15 build started
Post by lego4040 »
Re: AC15 build started
Holy crap there are a lot of turrets in one of these builds. :)
lego4040
Post by lego4040 »
Aside from a main cap board the AC15 has TWO full boards :shock: Sluckey put this together and squeezed into one thankfully.
TNblueshawk
Post by TNblueshawk »
Keep at it Lionel. I plan to look back on this thread, and the one at BYOC, when I build it at some point.
I'm letting you vet out all the frustration first :wink:
lego4040
Post by lego4040 »
Colossal
Post by Colossal »
Looks really good man. That's gonna be a helluvan amp!
lego4040
Post by lego4040 »
lego4040
Post by lego4040 »
rp
Post by rp »
This is fun to follow, very nice so far, please don't drop it. Curious why you mixed brown Xicons and 150s, just what you had, tight space, tone fine tuning?
I thought this was going into a Marshall chassis, I would have expected upright can caps, where does the doghouse board go in this, or is it for a fender BF style chassis?
lego4040
Post by lego4040 »
The Xicons were used because of tight space, it was designed to go in a 17" chassis but a 20" was recommended for extra room. No dog house I think, I will have to mock up and see if I can get it inside. The usage of top mounted transformers will give me a ton more room inside. There is one Mallory on the bottom just left of the Xicon I want to change too, I don't like the way I had to bend the leads. I'm taking it slow, I must've traced components ten times everyday to make sure I haven't forgotten something. Next purchase is gonna be a biggy, chassis and head along with all other parts :shock:
lego4040
Post by lego4040 »
:shock: Major Cash spent on parts today. I ordered my 20x6.5x2.5 chassis and cover. Sockets,fuseholder,lamp,nuts/bolts,grommets.........AND my complete tube set of JJ's for the build
lego4040
Post by lego4040 »
Masco
Post by Masco »
Nice. Lots of components per real estate there! I'd expect to see a lot of jumper wires underneath, but this layout is cleverly thought out. Kudos to Sluckey or whomever designed the layout. Hopefully it won't oscillate when you crank the treble... 8)
EL844??? Hummm.
sluckey
Post by sluckey »
Mine is done. And it works great. Here's a link to my project...
http://home.comcast.net/~seluckey/amps/index.htm
TNblueshawk
sluckey wrote:Mine is done. And it works great. Here's a link to my project...
Dang Steve, you made that process look easy. I've been following at Hoffman every step of the way.
