Dovetailed walnut cabinet
tubesinside
Post by tubesinside »
Love the way that this one turned out.
No gain...no pain!
Re: Dovetailed walnut cabinet
Wow!
That's a beauty! :D
Oil finish?
That is beautiful! But I can't see the dovetails!
tubesinside
Yes. That's an oil finish.
No gain...no pain!
Geeze
Post by Geeze »
Hi Tubeinside,
That is beautifully figured walnut. Good job on the grill and piping. How does the Ryan sound? 6V6 or equivalent?
Thanks for posting - I never get tired of great work and beautiful wood.
boots
Post by boots »
Gorgeous! Makes the pine cab I'm working on look like a toy. Nice work!
Don't you boys know any NICE songs?
JazzGuitarGimp
Post by JazzGuitarGimp »
Holy moly! She's a beaut!
Lou Rossi Designs
and Schematic Capture
sepulchre
Post by sepulchre »
Wow! That's a Fabulous look. Great job!
Great looking cab.
tubesinside
Russ. This is a strange sort of hybrid. It's got a JMP 50 watt power stage a Fender clean channel with reduced value bypass caps and a Dumble OD section with post OD 'James' tone stack. It also has a Fet driven parallel effects loop with return level on the front panel. Sounds great
No gain...no pain!
njwrecks
Post by njwrecks »
beautiful work mate!!!
Phil_S
Post by Phil_S »
Fabulous looking amp! Really. Fabulous.
Just curious though, why'd you put the amp on the top? I find is so much easier to put the amp on the bottom.
tubesinside
I hang it from the top because I want the option of using them in a combo or a head.
No gain...no pain!
NickC
Post by NickC »
Nice! 8)
summitcity
Post by summitcity »
That's amazing. Do you use capture nuts or wing nuts? I like the look better when you hang the amp but a bottom amp doesn't trap heat next to the tubes. I to like the option of using a combo.
