Two output Trannies in parallel?
cbass
Post by cbass »
So Is there a reason not to connect two Identical OT's in Paralell in a PP amp?
So if I had 2 8k Ot's with 4 and 8 ohm secondaries connected in paralell I could use them at 8k with 8 and 16ohm secondaries?
Re: Two output Trannies in parallel?
What are you wanting to run on the primary side? Are these PP or SE OT's?
cbass
Post by cbass »
Its Push-pull AB .I have two OT's from a PP AB stereo amp They are 8k primary with 4 and 8 ohm secondaries.
I am wanting to run them in parallel and have an 8k primary with 8 and 16 ohm seconadary
eniam rognab
Post by eniam rognab »
can i have your other OT? sounds like you wont need it....
cbass
Post by cbass »
So what are you saying .It's a stupid Idea?They are like little 12 wat transformers I thought maybe I could get some more headroom and bass response from the amp I'm building (6g3 deluxe)
eniam rognab
no no, im not saying anything, just joking, certainly not a stupid question.
sounds like alot of iron though....
sorry to sully your thread cbass... you da man (jabs shoulder)
cbass
Post by cbass »
Didn't mean to come off pissy .Lots of Iron is mo good.These things cant weigh more than 2lbs a pc I Think I can handle it
Leo_Gnardo
Post by Leo_Gnardo »
cbass wrote:So what are you saying .It's a stupid Idea?They are like little 12 wat transformers I thought maybe I could get some more headroom and bass response from the amp I'm building (6g3 deluxe)
I'd stick with a single OT. Plus, the output impedances won't add as you plan. Brown Deeluxe hm? Verrry nice indeed and just a pinch away from the Marshall 18W amps. Should be a winner!
For more bass, closed-back speaker cab. 15" speaker too. Hey that's a bass cab - don't tell anybody. Might consider using standard Deluxe replacement OT's if yours look small by comparison. More iron generally = mo bass.
cbass
Post by cbass »
I've got a good beefy old OT I can use. but it will need to be used with a 16 ohm cab .Buying stuff isn't really an option right now.
Is the ot in the brown deluxe the same as the tweed deluxe?
rock_mumbles
Post by rock_mumbles »
Two OT's connected completely parallel have exactly the same turns ratio so it would still be 8k to 4 or 8 ohm ...
cbass
Post by cbass »
Oh ok I thought it would cut the primaries in half
cbass
Post by cbass »
Well i'm from missouri so I can't just take someones word.SO iguess i'll measure the turns and see how it comes out.
eniam rognab
cbass wrote:Well i'm from missouri
i believe its pronounced "misery" :lol:
Firestorm
Post by Firestorm »
cbass wrote:Well i'm from missouri so I can't just take someones word.SO iguess i'll measure the turns and see how it comes out.
Mumbles is right. Inductance and power ratings change but the ratios don't. To change the ratio you have to go parallel-series or series-parallel, but then the impedances will change by a factor of four.
cbass
Post by cbass »
You ever notice that all the badasses Clint Eastwood plays I n his westerns are outta Missouri
