PCB Layout: Heater Traces / Wiring Best Practices
Garthhog
Post by Garthhog »
I have this amp I build... my HayMaker-50. It is currently a turret board / Point-to-Point hybrid (best way I can describe it). Anyway, I am considering converting it to PCB construction and I am trying to research best practices on layouts. I know that none of the rules change re: trace / wire proximity, etc. but I am wondering how to deal with the largest hum contributor: heater traces. I know that in a P2P or turret board build the wiring must be a TIGHT twisted pair right up to the sockets and all signal traces must cross at a 90 degree angle to keep crosstalk to a minimum. but on a PCB, unless you layout a fancy multilayer board with layer to layer ground vias, the heater trances have to live next to signal and control traces without the field cancelling benefits or shielding. So, I think there are a few options. One would be to make the heater wiring connection to the PCB right next to where each socket is soldered. Another would be to route heater traces East-West and signal traces North-South. Yet another is to leave the sockets as chassis mount, wire the heaters directly and run the signals to the PCB (same as turret board construction). Finally, I could just run DC heaters and worry less about crosstalk.
So, pros and luminous amateurs... which option would constitute a best practice when eliminating heater hum is of primary concern?
-Ryan
Ryan Brown
Brown Amplification LLC
gingertube
Re: PCB Layout: Heater Traces / Wiring Best Practices
Post by gingertube »
Ryan,
If putting the heater traces on a PCB then you just about have to go 2oz copper board.
Many guys wire the heaters in a normal point to point fashion and just put the amp circuitry on the PCB.
Given the number of PCB based amps on which I have had to repair heater traces I would recommend this approach. (a couple of Mesa amps come to mind, a MK2C was the last I had trouble with this).
Ian
Garthhog
Post by Garthhog »
Thanks, Ian. I agree about the copper. Proper PCB design should prevent most trace burning.
Ryan Brown
DonMoose
Post by DonMoose »
Like Gingertube said, but wire direct to as close to the pin as you can get. There's a line of Oranges that tried to use a string of connectors on a twisted pair, and those just did not work.
gingertube
Garthhog wrote:Thanks, Ian. I agree about the copper. Proper PCB design should prevent most trace burning.
And fuses on both sides of teh heater feed, rated at just less than the copper traces.
Ian
