Hey guys, Just wondering if anyone can give an idea before i open her up again... I had a traynor bassmate, modded the circuit a very small amount (mild tone shaping, switching to 12ay7 preamp tube) and loved it. Went to test it out the other day, and i noticed when i powered it up, it took a minute to power on, and the light (heaters) slowly cycled on/off stronger and stronger until it finally "powered up" Anyone see this before? I know it bounced around the trunk of the wife's car for a day, maybe stressed a cold solder joint... just never ran into an amp that cycles up like that. It worked when it powered up, but i didn't play it much, out of concern for what is going on.
Thanks in advance!
slow power up on traynor bassmate
Re: slow power up on traynor bassmate
Sounds very likely. Pull the tubes and start by checking the heater circuit for intermittent connections.guittech wrote:maybe stressed a cold solder joint
You should start your check out at whatever tube gets the heater connections right off the transformer!
