Cliff PC Jack problem
Marshall Amp Discussion
Randy Magee
Post by Randy Magee »
I have a single input JCM 800 Lead amp on the bench with a bad input jack. I can't seem to find a source for the Cliff jack that is used on this PC board. The pins that connect to the circuit board on any replacements that I can find are the reverse on the original. In the image below the original is the top jack and the replacement is the bottom. Does anyone know of a source for this reverse of normal PC jack?
Randy Magee
John_P_WI
Re: Cliff PC Jack problem
Post by John_P_WI »
When looking for a source, you need type PCA/S/Rev. Sorry can't answer the question but do know that Newark and MCM carry Cliff.
John_P_WI wrote:When looking for a source, you need type PCA/S/Rev. Sorry can't answer the question but do know that Newark and MCM carry Cliff.
https://www.tubesandmore.com/sites/defa ... s-h905.pdf
Looked around for an hour but could not find that jack I would contact sales at Cliff USA or UK for the part or part source.
Randy Magee
I think I'm just going to put a Switchcraft in there and be done with it...
Randy Magee
jaysg
Post by jaysg »
Randy Magee wrote:I think I'm just going to put a Switchcraft in there and be done with it...
It's an old amp. I think whether you go Switchcraft or Cliff, you'll have to fly the leads.
Randy Magee
You're right about flying the leads... there is not room for a cliff jack unless it's a PC jack that I can't source... I could get them from the UK, but I'd have to buy 1000 to get 1 and I don't figure this problem will come up 999 more times. I used a Switchcraft with insulating washers and it works just fine.
Randy Magee
