Vox AC30 build pt
Vox and Hiwatt Discussion
JoshBernstein
Vox AC30 build pt
Post by JoshBernstein »
Hi there,
I've started to build an ac30, and I've got a power transformer that id like to use, but I'm not 100% sure that it will be sufficient. Its secondaries are as follows: 280-0-280 @ 250ma, 6.3v @ 5 amps, and 5v @ 3 amps. I know the voltages will be fine, but will 250ma be enough on the 280-0-280?
Thanks!
-Josh
Not really
Stevem
Mmm
Post by Stevem »
Yes that's plenty , you only need 166 ma to power six ax7s and four 84s or 6V6s so your power will be real nice and your Bass will be very tight if that's what your after!
The only this is your V+ voltage will be higher than since the amp is not using all that current at idle .
Re: Vox AC30 build pt
I think you'll be fine. Compare the specs for this AC30 replacement PT: http://www.classictone.net/40-18050.pdf
JoshBernstein
Okay cool, thanks. Now about the ot... Looking at the drop-in-replacement specs, the primary for the ot is supposed to be 3.9k. What would be the consequences of using one with a 4.3k primary? How about a 3.8k primary?
Thanks again!
Not really
Stevem
Bbb
Post by Stevem »
The higher you go in primary impedance the less power output you will have , the longer the output tubes will last, and you will in turn have a lesser amount of output stage distortion .
In short if you want it to sound and respond like a Vox then stick with the stock spec!
SpeedRacer
Transformers for AC30
Post by SpeedRacer »
FWIW
- Heyboer has a custom part # I spec'd for them which mounts in the L-style original chassis. You could add an endbell and mount it normally too. It's #8047 I've gigged & recorded with it for about 10 years now. It's solid. It puts 330V on the plates (so 320 across the tube) just like the Mullard specs say to. It is rated for 250mA on the B+ winding. The idea here being to run cool and not melt like the stockers. ;)
- Stock OT is around 4k and is very nicely wound. The older ones used interleaved grain oriented laminations. By the mid 60's they were regular cores (and sounded great too) The OT is one of the keys to the whole amp IMHO. The HF response is dramatically better than any other guitar amp I've spent time with.
pdf64
Re: Transformers for AC30
Post by pdf64 »
SpeedRacer wrote: Heyboer has a custom part # I spec'd for them which mounts in the L-style original chassis. You could add an endbell and mount it normally too. It's #8047 I've gigged & recorded with it for about 10 years now. It's solid. It puts 330V on the plates (so 320 across the tube) just like the Mullard specs say to. It is rated for 250mA on the B+ winding. The idea here being to run cool and not melt like the stockers. ;)...
What's the plate supply impedance of its HT winding?
My understanding is that the PTs intended for tube rectifiers would normally have incorporated sufficient winding impedance to avoid the need for additional resistors. That would naturally result in them running hotter under load than PTs designed without that constraint.
http://www.mif.pg.gda.pl/homepages/fran ... 5/5AR4.pdf
