I was re-drawing the A1b schematic and adding a few labels and notes based on information gathered on this forum. As I was talking to myself the question came up: Are there any particular rules to the order of component numbering Obviously, for personal use, it doesn't matter. But if I was going to share this, I would want to follow the conventional methods.
Any suggestions
Component labeling rules
Tim
Re: Component labeling rules
Tim,
every amp layout I've ever seen with component numbers had a logic that numbered the components from the input to the output as seen on the schematic. On two channel amps it is typical to number the components through each preamp one by one and then the power amp. So you'd have for instance R1 through R25 in channel one, and then R26 through R50 in channel two etc. Then the power section would be next. That's what I've seen anyway.
Great things happen in a vacuum
That makes sense and is actually what I did. I thought I had better get a second opinionbnwitt wrote:...amp layout ... with component numbers had a logic
Thanks for your help
Tim
- skyboltone
Actually the whole enterprise makes sense to me. In the olden days, magazine articles used to publish schemes with component labeling as you've described, but also a bill of materials along with it.drhulsey wrote:That makes sense and is actually what I did. I thought I had better get a second opinionbnwitt wrote:...amp layout ... with component numbers had a logic
Granted that folks will need to vary things unless they are using the PRECISE iron that KF or Alexander used. Still, it would be a big help to say C6 22mfd (u) 25volts sprague electrolytic for instance.
Question of the day is, are you going to treat us to your work?
DanH
Without question I think I'm about finished with the Express schematic. I'll get it up as soon as it's done and let everybody check for mistakes. I'm working on a Liverpool schem, as well. Mind you, I'm just trying to make a schematic thats easy to read, has component numbers, tube pin numbers, etc. There is NOTHING original. It just helps me understand the circuit and makes a better reference for me during the build. I would never hesitate to share whatever I have with this resourceful forum, as long as it's accurate and doesn't confuse more than it helpsskyboltone wrote: Question of the day is, are you going to treat us to your work?
Tim
- skyboltone
Thanks Tim, I too have an easier time of things when everything is spelled out on the scheme.drhulsey wrote:Without question I think I'm about finished with the Express schematic. I'll get it up as soon as it's done and let everybody check for mistakes. I'm working on a Liverpool schem, as well. Mind you, I'm just trying to make a schematic thats easy to read, has component numbers, tube pin numbers, etc. There is NOTHING original. It just helps me understand the circuit and makes a better reference for me during the build. I would never hesitate to share whatever I have with this resourceful forum, as long as it's accurate and doesn't confuse more than it helpsskyboltone wrote: Question of the day is, are you going to treat us to your work?
Dan, I have posted the Express schematic on this thread to try to get some feedback for improvement and corrections:skyboltone wrote:...treat us to your work?
http://ampgarage.com/forum/viewtopic.php?p=25050#25050
I will do the same for the Liverpool when it's finished.
Tim
