Overdrive Special build
Aaron
Re: Overdrive Special build
Post by Aaron »
As fate would have it I just bought a Peavey Festival (Deuce). The iron is a fair bit bigger than the usual Fender option.
Does anyone know the specs for these transformers?
Aaron
erwin_ve
Post by erwin_ve »
Aaron wrote:As fate would have it I just bought a Peavey Festival (Deuce). The iron is a fair bit bigger than the usual Fender option.
Aaron
You can get the schematic for those amp below: afaik there are 2 kinds of setups. The 4X 6L6GC or the 6x 6L6GC (mace)
http://music-electronics-forum.com/t33321/#post306082
larsvictor
Post by larsvictor »
Peavy Festival is the "head only" version of Deuce II. Solid state preamp and 4 6L6GC poweramp.
PT should be EJ175. TAD replacement has the following specs:
MAINS for: Peavey® Deuce 240T, 120W, replaqces transformer EJ175
Primary:
0 V White
115 V Black
0 V White
115 V Black
Secondary:
0V Red
370 V Red
0 V Yellow
50 V Purple
0 V Orange
6,5 V Brown
lovetone
Post by lovetone »
Irwin
Just wondering if you had had the amp back to fit the front panel? if so did you investigate the interesting feedback you mentioned?
erwin_ve
Post by erwin_ve »
lovetone wrote: Thu May 04, 2017 6:24 am Irwin
Not yet, faceplate arrived finally. In 1-3 weeks the amp is here for fitting the frontpanel and some measurements, pics etc.
lovetone
Post by lovetone »
Looks good
i like the minimalist look, I just had a diezel big max in for repair that has the same idea the face plate is very simple and clean looking.
