SSS Cut Control?
Bombacaototal
Re: SSS Cut Control?
Post by Bombacaototal »
Krinkle wrote: Tue Apr 25, 2017 9:02 pm Any chance you have the pic?
It's here http://ampgarage.com/forum/viewtopic.ph ... 1&start=45
Note that #001 does not have the 470K and the coupling cap is .02uF
Krinkle
Post by Krinkle »
Can you see the traces underneath? I can't pick anything out, any clues?
Bombacaototal
Krinkle wrote: Tue Apr 25, 2017 9:15 pm Can you see the traces underneath? I can't pick anything out, any clues?
Aaron did a layout which is great! I think it is on the same thread
If you zoom in you can catch the traces
Krinkle
Post by Krinkle »
OK, I'll take a look. Thanks
Krinkle
Post by Krinkle »
Bombacaototal wrote: Tue Apr 25, 2017 9:16 pm
I think you might be on to something here.....
I'd expect some difference, but nothing too dramatic. Definitely give it a try and report back. Do you have the inductor in your circuit?
Krinkle
Post by Krinkle »
I don't. I'm torn now, I'll probably try both ways, yours and the one from Aaron's layout.
The inductor does not do much at all, so no big deal. When you say both ways, what are you referring to?
Krinkle
Post by Krinkle »
Your suggestion in Dumble Files and SSS001 as per Aaron's layout.
The major change in the circuit I propose in the files section is, as I say there, moving the cap to ground from one of the treble switch's position contacts to its center pole. That is what brings the treble response into line.
Krinkle
Post by Krinkle »
Bombacaototal wrote: Tue Apr 25, 2017 8:38 pm In my opinion there are other mistakes on the filters
I think before them it should be like the attached
If I did this with the SSS002, do you think I should place the 0.003 cap back to where it is on the Japanese schematic? I currently have it as per the May Contain Errors schematic.
Bombacaototal
Krinkle wrote: Thu Apr 27, 2017 1:51 pm
I would do it like attached. Let me know how it works out for you
Krinkle
Post by Krinkle »
Will do. Thanks B, much appreciated!
Krinkle
Post by Krinkle »
Bombacaototal wrote: Thu Apr 27, 2017 2:20 pm
No matter what I do, once I move the 3nF cap to switch position 7 to ground and take if off the common cap point, the non bypass positions are harsh as h#ll. With the .01 separated there is a marginal change in tone but not much difference.
Aaron
Post by Aaron »
Can you post some pics of your amp?
