Hey all, I'm building a new 18-watt circuit inside of my old Blues Jr. I'm not running a reverb circuit in it. Instead, the reverb knob is going to be used for a "cut" feature (though I still don't know how to succinctly describe how that works). Two questions:
Where would you look to get a new faceplate with the same specs as the blues jr one, but with different labeling? (I'd also like to get a new plate with the name of the amp on it for the circuit cover)
How much would you expect to pay for such an item?
Keep on rockin' in the free world!
Faceplates
Faceplates
I find it difficult to say "that's good enough"
Re: Faceplates
Get in touch with Jeanee at BnP Laser. She is great to work with. The lettering and frontpanel material and the number of holes all figures into the price.
Re: Faceplates
Might also be worth checking in with S2amps. He has a sideline in modded Juniors, and sends them back with new faceplates. He might sell one for less than it will cost to get one made....
__________________________________________
Cheers and Beers.
Cheers and Beers.
Re: Faceplates
+1 for Jeanne at BnP Laser. Can't say enough about the quality and customer service.
Omar
Omar
Tone by misadventure
- RJ Guitars
Re: Faceplates
Steve-O...
Let us know what you found. I've been converting Pro Juniors over to two knobber Hammond AO-35 specs and making my own faceplates... I'd love to find a vendor who would make them up a dozen at a time.
rj
rj
http://www.rjguitars.net
Re: Faceplates
talk to Joe at Amplates.com, very cool to deal with, great service.
- FUCHSAUDIO
Panels
I use www.jfhayduk.com for the Fuchs mods (back in the day).
A local trophy shop can often do a nice job too. They stock black plated brass, that when engraved, has gold lettering on it, and is rugged. PLastic looks good too, black with white letters, like the old Hi-Watt's....
BNP lasers is excellent as well. Jeanne's a peach !
update
I'm emailing Joe (at amplates) a jpeg of my faceplate tomorrow, as the new one needs to match the holes I've drilled out in the existing faceplate. I'm not sure what comes after that, but I'll let you all know.
Re: update
If you have one then a vector file (from Adobe Illustrator, CorelDraw, etc.) will provide better results than a jpeg. Or, if you're limited to a jpeg, then you'll want as high a resolution as you can.steve-o wrote:I'm emailing Joe (at amplates) a jpeg of my faceplate tomorrow, as the new one needs to match the holes I've drilled out in the existing faceplate. I'm not sure what comes after that, but I'll let you all know.
