Known Problems with the Site
I have two major problems going on with the site, and have had people asking about it, so I wanted to document them here. I'll keep this first post updated when I know there are issues, so people can check here to see, if not please reply here so everyone can see the latest notes etc.
The current issues:
1. The PM's and Updates no longer send out email. It even seems that almost no email is working right now.
2. The Tapatalk plugin no longer works, I'm getting errors in the logs that make no sense. - Fixed
At this time, I suspect both are due to the hosting provider but I can't get support to work right now either, I spent 10 minutes in a 'support chat' with nobody actually saying anything.
I've talked with Allyn about 1. but have no clear path forward yet.
The current issues:
Re: Known Problems with the Site
yes,cant login with tapatalk
Uncertain whether this was noted already. Regularly find certain internal links broken. Invariably these are in older posts, with the form "ampgarage.com/forum/download/file.php?id=######" where the number presumably is an file/object ID for photos or similar. The result of 'click-through' is the not so gratifying message <No route found for "GET /download/file.php"> Recent stumbled upon examples are in the following post from 2012 --- http://ampgarage.com/forum/viewtopic.ph ... 15#p219981. Perhaps simply the unsavoury byproduct of upgrading to get off the black list, or is there maybe some potential to repair this somewhat damaged history.
Best .. Ian
Best .. Ian
Just a small one...
On the board index page, upper right is a statement that tells when you last visited the site. For me it always reads "Last visit was: Mon Apr 24, 2017 8:58 am". Never changes.
I think this is possibly that the old site had either some custom download tool, or the phpbb 2 version had a plugin, and it didn't get migrated over to 3 I think all the files still exist, but not sure how to find the path to all of those. I may have to look into that a bit. Maybe there's a new 'download' type replacement and the same 'id' will work, and it's just a matter of me updating all the db links to the old path into the new path. I'll tinker.didit wrote: ↑Sun Oct 08, 2017 3:37 pm Uncertain whether this was noted already. Regularly find certain internal links broken. Invariably these are in older posts, with the form "ampgarage.com/forum/download/file.php?id=######" where the number presumably is an file/object ID for photos or similar. The result of 'click-through' is the not so gratifying message <No route found for "GET /download/file.php"> Recent stumbled upon examples are in the following post from 2012 --- http://ampgarage.com/forum/viewtopic.ph ... 15#p219981. Perhaps simply the unsavoury byproduct of upgrading to get off the black list, or is there maybe some potential to repair this somewhat damaged history.
Best .. Ian
That is an odd one, I think that several of the automated things on this site no longer work due to some change by the hosting provider. That's likely something that gets put in a batch job to be updated later and it never happens, like PM emails and updated thread emails. Just another problem that 'doesn't exist on other sites' that we have here, I think due to the hosting provider being crap.
I recently got onto one of their 'chat now' windows and waited for like 10 mins with not even a 'hello' from the support person that 'joined' in with me and gave up.
pompeiisneaks wrote: ↑Sun Oct 08, 2017 6:31 pmI think this is possibly that the old site had either some custom download tool, or the phpbb 2 version had a plugin, and it didn't get migrated over to 3 I think all the files still exist, but not sure how to find the path to all of those. I may have to look into that a bit. Maybe there's a new 'download' type replacement and the same 'id' will work, and it's just a matter of me updating all the db links to the old path into the new path. I'll tinker.didit wrote: ↑Sun Oct 08, 2017 3:37 pm Uncertain whether this was noted already. Regularly find certain internal links broken. Invariably these are in older posts, with the form "ampgarage.com/forum/download/file.php?id=######" where the number presumably is an file/object ID for photos or similar. The result of 'click-through' is the not so gratifying message <No route found for "GET /download/file.php"> Recent stumbled upon examples are in the following post from 2012 --- http://ampgarage.com/forum/viewtopic.ph ... 15#p219981. Perhaps simply the unsavoury byproduct of upgrading to get off the black list, or is there maybe some potential to repair this somewhat damaged history.
Best .. Ian
I think I figured it out already. The new format is: http://ampgarage.com/forum/download/file.php?id=14346 where the old is http://ampgarage.com/forum/download/file.php?id=14346
I need to likely update all the db entries that have
download/file.php and change it to download/file.php and that should fix it. I hope
Okay I was able to fix this. SOme of the attachments were deleted, so you'll now get a 'the file doesn't exist anymore' type message, but on that link you gave, several now find the right link.pompeiisneaks wrote: ↑Sun Oct 08, 2017 6:36 pmpompeiisneaks wrote: ↑Sun Oct 08, 2017 6:31 pmI think this is possibly that the old site had either some custom download tool, or the phpbb 2 version had a plugin, and it didn't get migrated over to 3 I think all the files still exist, but not sure how to find the path to all of those. I may have to look into that a bit. Maybe there's a new 'download' type replacement and the same 'id' will work, and it's just a matter of me updating all the db links to the old path into the new path. I'll tinker.didit wrote: ↑Sun Oct 08, 2017 3:37 pm Uncertain whether this was noted already. Regularly find certain internal links broken. Invariably these are in older posts, with the form "ampgarage.com/forum/download/file.php?id=######" where the number presumably is an file/object ID for photos or similar. The result of 'click-through' is the not so gratifying message <No route found for "GET /download/file.php"> Recent stumbled upon examples are in the following post from 2012 --- http://ampgarage.com/forum/viewtopic.ph ... 15#p219981. Perhaps simply the unsavoury byproduct of upgrading to get off the black list, or is there maybe some potential to repair this somewhat damaged history.
Best .. Ian
Thanks for reporting that!
Excellent, and ever so fast to patch.pompeiisneaks wrote: ↑Sun Oct 08, 2017 7:32 pm Okay I was able to fix this. SOme of the attachments were deleted, so you'll now get a 'the file doesn't exist anymore' type message, but on that link you gave, several now find the right link.
Okay so I did fix tapatalk today, I looked into just reinstalling it, and that seems to have fixed it. Not sure what I did in the recent 'update' I tried, but that seems to have restored it. Now if I can just get email working.
Phil, what does this time stamp actually mean: by pompeiisneaks » 18 72017v 6:12 -07:00Oct
Obviously I get the name part, but how do you read the time stamp?
Odd I don't see that, could be a problem with your browser cache? try a different browser and see if you get the same behavior or try to clear cache (this sucks, I know, all saved data is lost and you get to re-login to everything again, but sometimes it fixes really weird stuff)
Here's mine:
Here's mine:
Oh I did some looking around, and found an area you can 'change' the format of the date, maybe for your user account that got 'corrupted' you can go to your name in the top right, go to User Control Panel, and then look at this shot, you can change it to what you want here. Saving that in a format that you like may 'fix' it for you.
Phil, Thank You for this last bit of info, it changed the date to something I can understand! You Rock!!
Disconnected while editing
I have been disconnected while editing my message and I lost its content, while attempting to preview it.
My fault maybe?
This is frustrating, anyway.
I can use a text editor prior to posting, but couldn't the time before disconnecting a user be changed to something longer - provided it is both easy enough to achieve and desirable?
My fault maybe?
