Funkalicious OD Layout/Schematic
bnwitt
Post by bnwitt »
Is there a layout and or schematic for the chassis/board set Funkalicious Groove sold some time back? I think it's finally time for me to put it together.
Great things happen in a vacuum
pompeiisneaks
Site Admin
Re: Funkalicious OD Layout/Schematic
Post by pompeiisneaks »
I did a search and found this thread, where you'd asked the same question a few years back and in it funkalicious groove replies with what you can do:
http://ampgarage.com/forum/viewtopic.ph ... ove#p31000
Barry I'm not exactly sure which boards fit the Funk chassis.
I have one of his chassis too but mine has no silk screening all blank mine needs faceplate plus boards.
galtjunk
Post by galtjunk »
I bought 2 and built a bluesmaster in one and 183 in the other.
ic-racer
Post by ic-racer »
M Fowler wrote: Thu Oct 12, 2017 10:23 pm Barry I'm not exactly sure which boards fit the Funk chassis.
I believe J Boarders boards were modeled from Funk's. You'll have to check, but probably the eyelet boards I drew up (and Taylor produced) will fit. See in the D Files section. http://ampgarage.com/forum/viewtopic.php?f=5&t=29630
Thanks Martin I will check and see if they fit.
