Overtone HRM mods
MTR87
Overtone HRM mods
Post by MTR87 »
Hey guys,
Long time lurker, first time poster. I see a lot on this forum about modding the overtone but note much on the hrm model. I find that the HRM has too much high end for my tastes and I feel if I were able to tame it s bit I'd have a wider variety of usable tones. I play anything from blues to rock classic and contemperary. I have plenty of experience with electronics to mod this amp but I'm not knowledgeable on what a particular component change will do.
Any suggestions on mods for the HRM?
Thanks in advance.
Michael
Re: Overtone HRM mods
Hi, Michael!
Please point to a schematic for your amp, and I'll make suggestions.
First target for too bright amps is usually early in the circuit, like bright caps and treble peaking caps, before you even get to the tone stack.
MTR87
Post by MTR87 »
Here's a link to the layout: www.ceriatone.com/ceriatone/wp-content/ ... M-100W.jpg
Unfortunately the schematic is not available.
I really appreciate your insight, thanks!
The two mods I mentioned are A) clip or lift the 47pF bright cap on the MV. Probably won't make much of a difference, as 47pF is pretty small. B) clip or lift the 470pF treble peaker on V1 pin 7.
sonicmojo
Post by sonicmojo »
What kind of guitar are you typically using? This makes a big difference on these amps. One of the first builds I did was a Ceriatone Bluesmaster HRM. I added a high cut dial with varying capacitor levels near the end of the signal chain. There are old threads on that if you can locate them. It helps a lot with single coils, especially Strats. For Les Paul types with humbuckers I wouldn't typically need any cut, but this is just my experience with my one HRM type amp.
Bryan
Post by Mark »
What have you done regarding adjusting the HRM tone controls. I find they make quite a bit of difference. I also found it took a lot of time getting the pots adjusted right. I found I had to get the best sound from all the guitars I own.
MTR87
Post by MTR87 »
Hi Guys,
After tweaking the amp a bit and playing live, I'm fairly happy with the sound I'm able to achieve without mods.
That being said I think I'd like to change some component values to match an original ods hrm layout as posted on the amp garage to get closer to an original dumble amp.
Sonic mojo- I currently use a heritage Les Paul and a tele w/ 3 p90s. My understanding is that the high cut would only affect the lead channel, is that correct?
Mark - I haven't messed with the internal trim pots yet but my original concern was with the clean and overdrive channels and the internal trim pots only affect the overdrive channel.
