Can someone confirm or correct this list, please?
Non-HRM Classiq EQ : 3rd generation Period Correct ODS 50W, #40
http://ampgarage.com/forum/viewtopic.php?f=5&t=5986
Non-HRM Skyliner EQ low plate: #124 ( #102 Robben Ford's prior to skyliner EQ)
http://ampgarage.com/forum/viewtopic.php?f=5&t=5719
Non-HRM Skyliner EQ high plate: #183, #102 (Robben Ford's after the skyliner EQ was added)
http://ampgarage.com/forum/viewtopic.php?f=5&t=13095
http://ampgarage.com/forum/viewtopic.php?f=5&t=12873
HRM Skyliner EQ: #101
http://ampgarage.com/forum/viewtopic.php?f=5&t=5481
http://ampgarage.com/forum/download/fil ... &mode=view
Blues Master: 100 HRM in the Blues Master style
http://ampgarage.com/forum/viewtopic.php?f=5&t=3344
With respect, 10thtx
Dumble styles & corresponding amp #'s
Re: Dumble styles & corresponding amp #'s
Good idea. I would use nomenclature like this: ODS(-R) - <plate R config> - < clean tonestack> - <OD tonestack> - <derivative>
-R added to ODS indicates reverb
Plate R configurations are Low-Plate (all 100k) or High-Plate (220k/150k)
Clean Tonestacks are Classic or Skyline, and might have Deep or PAB, but AFAIK Skyline always has PAB.
OD tonestack is HRM, only if applicable (avoid using "Non-HRM"). BTW, I think HRM is "Hot-Rod Marshall.
Derivative would be Bluesmaster, e.g.
Maybe someone else can comment on this "system," i.e. does it cover the majority of cases... Max?
