Heavy strings, hard attack = Bad Express Tone
rooster
Post by rooster »
I just wanted to bring this up because for some reason this point has been driven home quite often lately. If you pick hard - like your playing an acoustic guitar 'hard' - and you use a gauge of strings bigger than a .009 - .042 - then you are not going to get an Express circuit. You will not find the experience enjoyable and you will not 'get' the Express. You need a disciplined pick attack and some finesse. The Express is a sensitive amp, not a BF Fender or a Marshall Plexi.
There, I said it. :D
Re: Heavy strings, hard attack = Bad Express Tone
I build them but I can't stand my playing through an Express.
Yup my string attack is hard so I enjoy a Marshall high gain amp or the Hot Rod Tweed "Bluesmaster" circuit 50w.
Roe
Post by Roe »
I prefer light strings and a softer magnet. Try the throbak magnets, e.g. unoriented alnico 5
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
2tone
Post by 2tone »
Yep.. Express tells you how it wants to be played..It does teach you about dynamics, more accurate picking etc.. You can't resist an Express, only join and comply!!!
Post by Mark »
I think strings do have a sweet spot on how hard you can strike them. 10-46 and 10-52 sound fatter and it's likely that you'll play them harder. I'm sure you can strum them softer too.
