Bassman Board ID
Fender Amp Discussion
dezmoduo
Bassman Board ID
Post by dezmoduo »
Happy 2018 TAG,
Probably 2, maybe 3 years ago I scored an incomplete "project" from Reverb or Ebay, It came wrapped in a decent Bassman head, with an original Bassman chassis, black nameplates (might be original), all new pots, and what looks like a prewired board installed. Xformers included.
Everything but the board was used as a donor to build a Bassman hybrid from Circuitrix. (Turned out great, lots of spaghetti, one of my gigging amps)
I think I almost ID'd this board way back then, with a Google Image Search, but I didn't save that result. On a whim & and prayer, if anyone can narrow my search parameter it would warm up my February. The bottom most turrets haven't been used yet, or by design, so that throws me off track a bit.
I retired this fall and there's projects a-poppin'
Best wishes and thanks to all,
Gary Lee
dezmoduo
Re: Bassman Board ID
Post by dezmoduo »
I'm going to go with an AA-165.
Stevem
Post by Stevem »
It's not the 165 as that circuit used a different bias set up where the 220k resistors in the PI section get fed separate bias voltage.
mauiboy81
Post by mauiboy81 »
AA864
The two unused turrets on the bottom of your pics would be for the bass channel deep switch which adds a .1 to ground in parallel with the mid cap. Scoops out more lower midrange when engaged.
