IF you've got the book/schematic, let me know if you think I've missed anything obvious, or should do something different.
Optional easy tweaks to the layout would be to run grounding wires between grounding points on the preamp sections and only run one wire off the board, (except for the power filtering which should be separate, unless you want to do 100% star ground) and you could also separate the power filtering into a separate board somewhere.)
I may eventually get around to building it myself, but have too many items on my build list at this point
![Razz :P](./images/smilies/icon_razz.gif)
Edit: Updated the layout, had the pots wired all wrong (backwards) and I had them off a bit as well, thanks sluckey
Edit1: newest version with corrections again by sluckey.
