Fender HRD Conversion to 2nd Generation (Hybrid)
jam-mill
Post by jam-mill »
Gutted my old (from 1995) Fender HRD and have begun the process to convert it to a 2nd Generation D-Style amp.
Fabricated some tube socket holders for the pre-amp tubes and made the board set.
John 15:12-13
Re: Fender HRD Conversion to 2nd Generation
Nice. I really like the HRD cabinet. I made my own 6G6B in such.
Start of a very nice conversion.
jam-mill
Post by jam-mill »
Any advice on what to do with the reverb tank?
Is there a tube circuit that can drive that 600 ohm input?
Sure would hate to have to use an IC...
John 15:12-13
A replacement tank is cheap; go with your favorite circuit.
jam-mill
Post by jam-mill »
Completed this build awhile back, but did not post a completed gut shot.
Also, the signal level into the phase inverter seems way too hot - any idea how to address this without affecting the overall tone?
This amp sounds really good when cranked up (as others have noted); albeit, a tad on the bright side.
Not sure if I should add snubbers or put in a treble bleed circuit. Any advice from those that know about the original would be greatly appreciated.
John 15:12-13
jam-mill
Post by jam-mill »
xtian wrote: Sun Mar 04, 2018 9:30 pm A replacement tank is cheap; go with your favorite circuit.
I built this (https://ampgarage.com/forum/viewtopic.p ... 13#p392013) to mount inside the cabinet.
John 15:12-13
jam-mill wrote: Fri Nov 23, 2018 8:13 pmThis amp sounds really good when cranked up (as others have noted); albeit, a tad on the bright side
What's your plate voltage?
jam-mill
Post by jam-mill »
xtian wrote: Fri Nov 23, 2018 9:42 pm
B+1 = 287V
B+2 = 296V
B+3 = 411V
B+4 = 436V
B+5 = 438V
V1 - 12AX7
V1A = 195V
V1B = 202V
V2 - 12AX7
V2A = 200V
V2B = 202V
V3 - 12AT7
V3A = 283
V3B = 280
V4 = 434V
V4 cathode current = 31mA
V5 = 435
V5 cathode current = 29.4 mA
John 15:12-13
Re: Fender HRD Conversion to 2nd Generation (Hybrid)
"A tad on the bright side" will probably sound a lot better if you can get the plate voltage down in the 350-400 range.
jam-mill
Post by jam-mill »
xtian wrote: Sat Nov 24, 2018 6:09 pm "A tad on the bright side" will probably sound a lot better if you can get the plate voltage down in the 350-400 range.
Aaron - thank-you for the information.
Any idea why the phase inverter input would be so sensitive?
Getting signal bleed even with the OD relay removed. Have also "chopsticked" to no avail... ;-(
John 15:12-13
The signal into the PI...when using the clean channel? OD channel?
If the clean channel is too hot, do you mean you get a lot of distortion from the clean channel?
jam-mill
Post by jam-mill »
xtian wrote: Sat Nov 24, 2018 7:54 pm The signal into the PI...when using the clean channel? OD channel?
There is no distortion, only that signal is reaching the phase inverter despite breaking the connection
to its input. Could it be a result of the dual-master set-up?
The problem is that even with the effects loop signal path broken there is still a significant signal bleeding
from the pre-amp into the power amp. The bleed is much more pronounced with the OD engaged.
John 15:12-13
jam-mill
Post by jam-mill »
One more thing - based on the information provided above, it would seem that the voltages on this layout (https://ampgarage.com/forum/viewtopic.php?f=4&t=12621) are incorrect; or, at the very least misleading.
John 15:12-13
jam-mill wrote: Sat Nov 24, 2018 10:21 pmThere is no distortion, only that signal is reaching the phase inverter despite breaking the connection
Ah, OK. To find what's wrong, we need to see the schematic you've used. Show me where you've disconnected the signal from the PI.
