Crate Stealth Head to 2x12 conversion
My friend is getting a little long in the tooth to be lugging around Crate Stealth head and 4x12 Jackson cab so I built this 2x12 Bluesbreaker style combo cab. Still a bit heavy but not near as bad as before!
- Attachments
- Crate back.jpg (10.23 KiB) Viewed 2513 times
- Crate top.jpg (24.6 KiB) Viewed 2513 times
- Crate front.jpg (12.47 KiB) Viewed 2513 times
Re: Crate Stealth Head to 2x12 conversion
Yes Any type of wood is a good amount lighter then particle board!
- Leo_Gnardo
Looks great, show off some real wood grain! Now if you can get him convinced to load it up with some neodymium magnet speakers, it should just about float off the ground. Well, save another 10 pounds or so anyway.
