JTM 45 clone ghost notes
Marshall Amp Discussion
casey73
Post by casey73 »
I built a JTM45 clone on a chassis I purchased from Antique Electronic Supply. They had most of the parts except for the lower voltage British 45 PT, that I purchased from Mojotone.
The only deviation I made from the original was to put 1K screen resistors in place of the original 470 ohm resistors. I've run it with the Valve Art KT66, original Svetlana EL34s and TAD 6L6s. Filter caps are F&T 16/16 dual section. The ghosting is there with all three tube sets.
Could I get rid of the ghosting if I replace them with 32/32 or 50/50 caps?
Re: JTM 45 clone ghost notes
There's a very long thread that worked through this. You could start here: https://ampgarage.com/forum/viewtopic.p ... 81#p397481 That one was a Metro, and a solution was found using the existing filters and layout. What schematic did you follow in yours?
Stevem
Post by Stevem »
Is the ghosting there at all volumes levels?
If not then at what level of V+ drop from idle on the plates of the output tubes does it start to show up?
casey73
Post by casey73 »
martin manning wrote: Fri Nov 01, 2019 10:28 am There's a very long thread that worked through this. You could start here: https://ampgarage.com/forum/viewtopic.p ... 81#p397481 That one was a Metro, and a solution was found using the existing filters and layout. What schematic did you follow in yours?
I used the original Bluesbreaker version but left out the tremolo circuit. I'll read through the thread. Thanks.
casey73
Post by casey73 »
I read through the long thread about the ghosting issue. Since a 5AR4 rectifier can safely handle up to 60uf at the output, is there any reason I can't just replace the 16/16uf caps with 50/50 caps?
Roe
Post by Roe »
50uf is ok, 32 is original. I'd check grounding and the balance of the phase inverter, not just the filtering
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
pdf64
Post by pdf64 »
casey73 wrote: Fri Nov 01, 2019 3:48 am...Filter caps are F&T 16/16 dual section. The ghosting is there with all three tube sets.Could I get rid of the ghosting if I replace them with 32/32 or 50/50 caps?
The caps for the reservoir and screen grid node should be 32uF.
casey73 wrote: Fri Nov 01, 2019 4:53 pm...I used the original Bluesbreaker version but left out the tremolo circuit...
Link to the exact circuit you used is necessary, as the original has a significant error http://raw-sewage.net/images/jtm45orig-schm1.jpg
This is how it should look http://raw-sewage.net/images/jtm45-readable.jpg Spot the difference? The error would result in the choke being overloaded and so losing most of its inductance, resulting in a poorly smoothed HT.
casey73 wrote: Tue Nov 19, 2019 2:27 am...Since a 5AR4 rectifier can safely handle up to 60uf at the output, is there any reason I can't just replace the 16/16uf caps with 50/50 caps?
Depends on the goal of the project; if it's still to build a reasonably valid clone of the circuit, then no. If it's changed to a 'based on a JTM45', then have at it.
A good approach is get the original circuit working correctly first, before tinkering with it.
burger
Post by burger »
I've had this issue on a 50w plexi. The mains filter cap was bad - start there.
What's your plate voltage?
This is a handy general trouble shooting resource,
https://robrobinette.com/Tube_Guitar_Am ... ooting.htm
http://headfirstamplification.com
casey73
Post by casey73 »
An overdue update on my ghost note issues. I looked at many threads on this and other sites regarding this. I had a few people chime in that the JTM45 is notorious for some ghost notes. I ended up replacing both the 16/16 and 32/32 F&T caps with 50/50uf F&T caps. The ghosting is gone. I still have a minor glitch with high pitched squeal IF you jumper the treble and normal channels, turn both volumes past 12 o'clock, the treble way up and push the presence past 7. After replacing the feedback lead from the turret board to the presence pot, having it go straight down the the chassis and hug the chassis up to the terminal on the pot, and removing the presence pot ground, giving it a separate lead to the ground lug, it still squeals at that setting. My lead dress throughout the amp is very clean and meticulous. I've decided to live with it as I would never normally set the controls like that. And, after quizzing other forums in addition to this I've had other JTM45 owners say this has happened in their amps also.
Roe
Post by Roe »
presence squeal is normally cause by lead dress and lack of faraday cage (add a metal sheet inside the headcab)
4x12" w/H75s
pdf64
Post by pdf64 »
The absence of grid stoppers on the power tubes is an invitation to instability.
casey73
Post by casey73 »
Roe wrote: Thu Feb 13, 2020 8:22 am presence squeal is normally cause by lead dress and lack of faraday cage (add a metal sheet inside the headcab)
My lead dress is very clean and I do have a sheet of aluminum across the bottom of my head cabinet. I think it is just part of the design. On other forums I've heard similar complaints from other JTM owners. It seems to be a common complaint even in vintage units. Not universal, but not uncommon. Like I said, I'm going to leave it alone since it only occurs on extreme settings most would not use.
casey73
Post by casey73 »
pdf64 wrote: Thu Feb 13, 2020 9:32 am The absence of grid stoppers on the power tubes is an invitation to instability.
I have 1.5K grid stoppers mounted to the tube pin, going straight up with lead soldered to the end. I did vary a little from the original design including 1K screen resistors and I bumped the filter caps up to 50/50uf, which stopped the ghosting. I might try higher value grid stoppers next time I have it open. I've read up to 5.6K can work without having a audible effect on the tone. For the time being I'll leave it.
Roe
Post by Roe »
casey73 wrote: Sat Mar 14, 2020 4:48 pm
I've been able to cure the presence squeal on all plexis and alumium panel amps I've had at my bench (20-30 amps). Just move the purple NFB wire
4x12" w/H75s
Stevem
Post by Stevem »
Yup, use shielded wire for the feed back fed and go over the orientation of your coupling caps.
