CUSTOM FRONT/BACK PANEL MAKERS
I thought I'd ask if anyone knows of a good custom front/back panel maker for a Valvestorm project chassis build? Thanks.
Just plug it in, man.
- dorrisant
Re: CUSTOM FRONT/BACK PANEL MAKERS
I can do it. What do you have in mind? Of course I'd have to have the dimensions...
I ended up using front panel design. I mainly used them because i wanted some uv printing done to the panels plus engraving. You can make the printed part in something like affinity or adobe then use the fpd software for the engraving and holes. The fpd software lets you import the graphic you made to be printed so it can be anyway you want it. They are expensive though but the panels came out great imo.
- romberg
I've used Precision Design to make faceplates for many custom amps I've built. Sandy is very fast and has been able to do lots of custom things I did not think possible:
http://www.precisiondesignin.com/
Mike
Mike
I think they all have the same machines these days: CO2 lasers, dye-sub printers, etc.
Do any Australian members have any recommendations for Panel Makers in Oz?
Getting panels done in the US, or anywhere else, is too expensive now that our Au$ is crashing and international postage (from anywhere to Oz) is too costly also.
Can u do front/back panels that works to order from TT
https://www.tube-town.net/cms/?TT_LaserShop/Quickstart
- dorrisant
zvenamp wrote: ↑Fri May 15, 2020 7:23 amCan u do front/back panels that works to order from TT
Yes. PM me.
