15H choke for 2x6L6 blackface-type amp?
Fender Amp Discussion
Dingleberry
Post by Dingleberry »
Hi.
I'm in the process of building a 2x6L6 "Blackface"-style amp and I have an old recycled choke on hand that I plan to use.
I loaned a LCR-meter from my friend to check the inductance and it reads about 15 Henrys and dcr is 159 ohms.
That's about 4-5 times more inductance that Fender used.
How will that choke behave? Feel more "stiff"?
I'm going with ss-rect (no 5V tap in my PT) and a bit larger filtering for b+ as I'm aiming for big clean tone.
Has anyone used bigger chokes in Fender builds?
-T
Simplify before you amplify
pdf64
Re: 15H choke for 2x6L6 blackface-type amp?
Post by pdf64 »
Bear in mind that inductance may change with current (ac and dc), and collapse when the saturation current is exceeded.
Have you tried measuring the inductance of chokes whose spec you know?
Dingleberry
pdf64 wrote: Mon Apr 06, 2020 3:51 pm Bear in mind that inductance may change with current (ac and dc), and collapse when the saturation current is exceeded.
Hi!
I measured few chokes of different Henry-scale (uH - H) whose specs I know and it most likely looks like that the meter (Wavetek Meterman LCR55) is calibrated right.
So if (and most probably) it's a 15H choke, what would be the benefits and "negative" sides of using one in the PS of a that kind of amp?
-T
Roe
Post by Roe »
it will sound crisper and cleaner with tighter bass but slightly more screen sag. I generallt prefer 3-4h for fenders and marshalls
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Dingleberry
Thanks for the replies. I think I'll pass that choke and get a new one better suitable for this project.
-T
pdf64
Post by pdf64 »
Roe wrote: Tue Apr 07, 2020 6:11 am...slightly more screen sag...
Fender choke resistance typically seems to be 100-120 ohms, for the larger amps, 150-200 ohms for the smaller amps (inc the Vibrolux). So at 159 ohms, the resistance of the choke here seem in the normal range for Fenders? So the sag character shouldn't be affected?
Roe
Post by Roe »
pdf64 wrote: Wed Apr 08, 2020 12:32 pm
its a little more more than 100ohms but the effect might be sublte.
4x12" w/H75s
