Source for shielded hookup wire?
clarkleach
Post by clarkleach »
I need some shielded cable like used in amps to connect the input jacks and tone controls (1 conductor + shield).
So far, Mouser has been my only hit but I don't want to buy a 100' roll.
Anybody got a good connection?
echuta13
Re: Source for shielded hookup wire?
Post by echuta13 »
I use Canare GS-4 which I buy from Redco: https://www.redco.com/Canare-Instrument-Cable/
I also buy my PTFE tubing from them: https://www.redco.com/Redco-TT250.html
They're pretty quick to ship and I've been happy with them. :)
If you can't be a good example, then you'll just have to be a horrible warning.
clarkleach
echuta13 wrote: Fri May 22, 2020 4:38 am I use Canare GS-4 which I buy from Redco: https://www.redco.com/Canare-Instrument-Cable/
Thanks for the tip. Looks good. Is it safe to assume this stuff doesn't melt instantly when you try to solder it?
What do you use the tubing for?
Mac Dillard
Post by Mac Dillard »
Not sure exactly what you are look for but: McMaster Carr sells RG174 in 25 foot minimum.....Hoffman over at EL34 World sells RG174 by the foot
echuta13
Post by echuta13 »
clarkleach wrote: Fri May 22, 2020 5:22 am
The cable holds up well to heat so shouldn't be a worry. The PTFE tubing is for lead isolation for off-board components. Takes heat exceptionally well.
jcool666
Post by jcool666 »
I just use rca cables from old tv and stereo equipment. Its shielded and basically free. Who doesnt have 2 or 3 cables hiding in a closet somewhere?
"Dime the controls, tune to drop D and flog the strings like they were naughty,"
bal704
Post by bal704 »
I've started using what I call faux-shielded cable for my builds. I take a regular wire and make whatever connection I'm making. Then I take another wire, ground one end, and wrap it around the other wire. I leave the other end unattached, and use heat shrink tubing for the last inch or two to keep the whole thing from unwrapping.
Basically I hated cutting and stripping shielded cable, so I found another way. I don't build super high gain amps, but it seems to work.
Phil_S
Post by Phil_S »
My experience is that Steve at Apex Jr will fix you up with a small quantity for a reasonable price.
http://www.apexjr.com/
I like the idea of making your own. I don't like striping and soldering the shield either, and I often find the inner wire uncooperative.
