Sufficient B+ for Dumble kind of preamp?
Mr. Lime
Post by Mr. Lime »
Hi guys,
having a lot of amps standing around and taking my place to live, I would like to build a stompbox preamp with two 12AX7.
There's an available voltage pump kit that supplies a maximum of 15mA @ 220V DC out of 4 VA @ 12V DC input.
I don't expect this preamp to be a close reproduction of the Dumble sound but would 220V get me in the ballpark?
Thanks a lot!
pompeiisneaks
Site Admin
Re: Sufficient B+ for Dumble kind of preamp?
Post by pompeiisneaks »
I found this looking through the #124 section: https://ampgarage.com/forum/viewtopic.php?f=5&t=5719
B+ is 440VDC on the 6L6 plates, which seems low. The remaining plate voltages are: V1A and V1B approximately 190VDC each; V2A and V2B 10 volts higher; on the order of 280VDC for the non-feedback side of the phase inverter plate, and about 10 volts higher for the feedback side.
Which if I do the math means;
V1: 190VDC, V2: 200VDC/210VDC
Then another note later:
22) Were any voltages measured when the amp was examined?
Yes, as follows:
V1 190v
V2 200v
6L6 Plates 440v
PI plates 280v and 290v
So yes, that voltage 'should' put you in the ballpark, but you'll need to play with the a dropper resistor before the V2 tube and then another for V1...
But...
That's definitely only one component in the variable list... :)
pompeiisneaks wrote: Thu Nov 19, 2020 6:56 pmWhich if I do the math means;
Yes, preamp tube plate voltages are 190-200V, but that means the supply voltage would have to be about 300V at 5mA to replicate the ODS operating points.
pompeiisneaks
Site Admin
martin manning wrote: Thu Nov 19, 2020 7:09 pm
Ahh you're right, I didn't think of that exactly, so that's direclty ON the pin...
So yeah, that definitely won't work unless you use a FWB Rectifier, which should make the output voltage be over 300V? (FWB is 1.4x the output AC whereas FW is .9) that would work I think?
The OP is wanting to use a SMPS of some kind to get the HT from a 12VDC input. Looks like the one he is considering tops out at 220V.
pompeiisneaks
Site Admin
I'll hush and stop derailing with my misunderstandings then.
Mr. Lime
Post by Mr. Lime »
Right, the PSU delivers a maximum of 220V - is it worth trying?
Mr. Lime wrote: Fri Nov 20, 2020 10:47 pm Right, the PSU delivers a maximum of 220V - is it worth trying?
It will work, but your plate voltages will be low, around 140V instead of around 200V, so you will lose headroom. I'm sure it's possible to build a 300V, 5mA SMPS.
Mr. Lime
Post by Mr. Lime »
That's the voltage pump I would use:
https://tube-town.net/info/datenblaette ... t_v1_6.pdf
