Tension - Resistance - Current -- Not strictly a technical amp info
- Kagliostro
Re: Tension - Resistance - Current -- Not strictly a technical amp info
I read around 1 Meg dry skin resistance. If you puncture the skin though, it drops to 200 Ohms. So a voltage you can't normally feel, can generate a large current if the skin barrier is broken, say on a sharp lead or solder connection. If you smell bacon, let go.
As far as the heart goes, the timing of the shock is a critical factor. If even a small shock is received during the T wave of the cardiac cycle (the dark green area), when the left ventricle is repolarizing, it will fibrillate and death will result. This can occur with less than 3mA of current.
It's important to recognize dry human skin has an insulating resistance, which will breakdown when an applied voltage reaches a high enough level. Once the dielectric withstand voltage is reached (500-550VAC for dry human skin), the insulating layer is punctured and exposes a persons much lower internal resistance.
Here is a High Voltage Safety Manual from the University of Colorado which has some good info, and a study published in the biophysical journal on the electrical properties of skin at moderate voltages:
This is great info, as now I know that if I am stuck between a rock and a hard place when I need for instance a 4K preamp tube cathode resistor I can just splice myself in between my foot and my hand!
I just went to a medical site and became a member and proceeded to post up info for how to use a long tail Phase splitter to reduce the chance of blood clots after surgery!
Stevem
Yeah, it's given me an idea for my next project.
I'm going to replace the preamp cathode resistors with some of my favourite guitarists for the ultimate rock tone. I reckon Vai, Satriani, Gilmour and Robben Ford would do for a start. Just not sure if I will have to soak them first, and whether to bypass Vai with a capacitor... and if so what value???
Should sound awesome!
Ritchie Kotzen is the best choice for a cathode resistor, his initials are even Rk.
Lol!
Great call - not familiar with that guy.. now rocking his greatest hits on youtube - AWESOME - thanksRitchie Kotzen is the best choice for a cathode resistor, his initials are even Rk
Ok folks, I just got a reply back from that medical site that I joined and was informed that a pacemaker can be modded to trigger the speed of a tremolo circuit.
Also playing with long sustain or feedback can treat reflux.
Preliminary studies support the common experience that drum solos cause indigestion and repeated exposure can cause GERD. Auto tuned vocals are safe, they just cause transient nausea.
