Wanted to get your opinion on something. I've asked this on a different forum but I believe the general consensus here is different - apologies if you've seen this thread on that other forum.
I recently picked up a non-functioning 1966 AB763 Showman. It's by no means mint. It's blonde so was likely re-covered, although, some on the other forum thought that it looked like Fender quality - it's highly doubtful that Fender covered a showman in blonde in 1966, from what I understand. Even if it was done by Fender, it's in pretty rough shape. The PT and OT have both been replaced. A previous owner has attempted some mods. All that to say, it's far from mint.
One thing it does have going for it is that the guts appear to be dang-near all original. I plan on replacing all of the electrolytics (on the filter AND main board). I'm also going to replace the resistors that read out of spec and/or obviously need to be replaced. Finally, I think I'm going to up the wattage on the screen resistors as it looks like one of them blew apart at some point.
My goal here is to retain as much of the '66 vibes, without being too crazy about it. As it's already far from mint, I guess I'm not super concerned about a loss of value.
Here's what I'm thinking:
1. F&T electrolytics
2. NOS Allen Bradley Carbon Comps for 1/2 watt resistor replacements
3. New production carbon comps for the screen resistors with a rating of at least 2 watts
Any thoughts / opinions on that?
I do have 2 additional questions (I'm going a, b, c, format on these
A. Should I need to replace any of the blue molded caps, is there a recommended replacement? At this point, I'm planning on yellow Mallory 150s as I really like them in my DIY Princeton Reverb.
B. Any reason that I should or shouldn't re-cover the cabinet?
Pictures to follow, of course!
