BYX94 diode
BYX94 diode
I'm wondering about the BYX94 diode used in the Hiwatt DR103 amp, is there any other diode that can substitute for it? I am waiting for the order, but maybe I have some I can use while waiting Post is very slow these days.
- statorvane
Re: BYX94 diode
I have used these a lot: 1N4007: Standard Rectifier, 1000 V, 1.0 A
I recently started using these: 1N5408: Standard Recovery Rectifier, 1000 V, 3.0 A
I am familiar with the sluggish USPS delivery these days. I ordered a tube and a couple of pots 2 weeks ago, 2nd or 3rd business day. It's been two weeks.
Re: BYX94 diode
Thanks for that. So it's sort of a standard rectifier diode?
Re: BYX94 diode
BYX94 is older design 1250V@1A rectifier with designer notes recommending it for the application. 1N4007 spec less tolerant with 1000V@1A. I have been using this 1500V@1.5A rectifier https://www.vishay.com/docs/88567/cgp15.pdf, which is ROHS & readily available from the usual places - Mouser, Digikey, etc. for the modest price of about $0.50 in small quantities.
Best .. Ian
Best .. Ian
Re: BYX94 diode
My schematics says 4 byx94's.
Re: BYX94 diode
Hi Sluckey and thanks. Used your AC15 Brilliance switch in my AC15 build. Works great-
Included is the schematics I use fro the DR103 build. I used some diodes I had, but got some pretty glowing 100w lamp limiter at start up, som I am waiting for the new diodes.
Re: BYX94 diode
Sluckey's not questioning your point. He's pretty sure you're missing his. His point is even the company building them, decided the 1N5408 fulfilled the requirements just as well.Oddvar R wrote: ↑Sun May 09, 2021 2:47 pm Hi Sluckey and thanks. Used your AC15 Brilliance switch in my AC15 build. Works great-
I.e. rectification, is rectification, and so long as you get DC on the other side, it did the needful.
Re: BYX94 diode
The document I linked to is directly from the Hiwatt company. Here's another Mark Huss drawing...
Re: BYX94 diode
What is the difference you say?
Re: BYX94 diode
Read the note in the bottom left corner of the schematic.
