Is this worth $250?
Phil_S
Is this worth $250?
Post by Phil_S »
https://baltimore.craigslist.org/msg/d/ ... 31967.html
I wasn't looking for a project, but I'm a sucker for Gibson amps and this one is local. What's the group think on this one? I give it 9.9/10 on cosmetics. The "n" is partially missing on the logo. The rest is anyone's guess.
sluckey
Re: Is this worth $250?
Post by sluckey »
I'd pay $250 for it.
Phil_S
Post by Phil_S »
I know the circuit. I have a GA17-RVT, which is basically the 6AQ5 version of the amp without the choke and the other weirdness with the OA2 and the 6FQ7. I don't see how I can diagnose the problem quickly if I were to see it. It passes sound, so I'm thinking it needs a cap job, other maintenance and tubes replaced. These things are all manageable. The problem I'm concerned about is if any of the iron isn't in good order. A replacement OT may be impossible to source at a reasonable price. MM sells one for $180, though I'm thinking no one knows what it sounded like back in the 1960's so I might find a suitable Hammond or other generic if needed. If the LDR based optoisolator for the tremolo is toast, there is no substitute available, so it has to be hand rolled. I might take a chance. I'll contact the seller and see if it's still available.
pdf64
Post by pdf64 »
There will be workarounds / fixes for everything.
If a transformer is bad, Hammond should have something of a closely similar spec, from one or another of their ranges.
Phil_S
Post by Phil_S »
It turns out this amp is worthless because the person who posted the ad on CL isn't responding. :(
Really, it's so rude. He should either remove the ad or let me know. I don't think it's too much to expect. Apparently, it is.
Colossal
Post by Colossal »
Phil_S wrote: Mon Jul 26, 2021 6:52 pm It turns out this amp is worthless because the person who posted the ad on CL isn't responding. :(
The seller has shown his true qualities and behavior like this is the rule these days, not the exception. You probably dodged getting ripped off.
Phil_S
Post by Phil_S »
Colossal wrote: Mon Jul 26, 2021 8:15 pm ... You probably dodged getting ripped off.
I suppose so. It's a good ending. Thank you for putting a good spin on it.
