5E3 Transformer: Heyboer or PacificAudio?
Fender Amp Discussion
rschiller
Post by rschiller »
I've built more complex amps (AB763 + Trainwreck, Boogie, Marshall 2204, etc w/ optoisolator switching & reverb) and am going to do a 5E3 because they sound great. Several good options for transformers though I will avoid Mercury Magnetics as I tried one of their 5E3 OTs in an original 1958 5E3 and thought it too "modern" sounding. I had a problem with the original multi-tap Stancor A3880 not putting out enough power amp and Mercury advised me the transformer was shorted internally and needed a rebuild; turns out the taps were not set properly and the transformer is fine.
Narrowed down to going with either a set of Heyboer or PacificAudioMagnetics. Anyone have any thoughts or comparisons on these? Or other suggestions?
thanks to all.
ViperDoc
Re: 5E3 Transformer: Heyboer or PacificAudio?
Post by ViperDoc »
I’ve never seen anyone turn down a Heyboer, especially these days.
Just plug it in, man.
jabguit
Post by jabguit »
I'd go Pacific.
cheers,
Jack Briggs
Briggs Guitars
Stevem
Post by Stevem »
If there is a weight difference between the two and you would like the bottom end to hold together a tad better then how the original Fender one did then go for the one with more mass.
