Long-tail pair phase inverter
So I'm looking for offbeat design ideas to get away from 12ax7/12at7 tubes. I've got a few 12sc7 tubes kicking around and I was thinking about using one for a phase inverter. I know it was common to use it in a paraphrase arrangement (the 6sc7), and with a single cathode it's not possible to do a cathodyne inverter, but has anyone seen one used in a long-tail pair arrangement? Seems possible to me since the ltp has the 2 cathodes tied together anyway.
"Dime the controls, tune to drop D and flog the strings like they were naughty,"
Re: Long-tail pair phase inverter
Yes, you can use it and it will work fine.
Being on the "not often seen in guitarland" scenario, you can also use a simple CCS from the common cathode to a negative voltage (obtained from raw bias) and avoid a coupling cap from the tonestack to the phase inverter.
Target twice the current of each triode, and keep the two plate resistors the same.
