Hi.
I have Blackface Dual Showman from 1966 with Dual Showman output transformer 022897. I'm not sure is this originaly there or somebody replace that.
Shoud I also change the last resistor in NFB loop?
I measured 100R as it shoul be in Dual Showman, but with Showman output transformer should I change to stock 47R?
Is this an important thing or I can leave it like that.
Thanks!
Fender Dual Showman with Showman output transformer
Re: Fender Dual Showman with Showman output transformer
It’s fine to leave it as is. There’s a bit more negative feedback, leading to a tighter response.
You will very likely never play it loud enough to hear the slight difference that it will make.
Great!
Thank you guys for the help.
try a 100R in parallel to see what you like
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
Where are you getting info on the 022897 ? I'm not finding that number on any Showman or Twin schematic. The "Showman Amp" or "Single Showman" should have an 8 Ohm output while the "Dual Showman" should have a 4 Ohm output.
022897 - Vibrosonic reverb
mentioned in Twin 100w schematic - http://www.thevintagesound.com/ffg/sche ... _schem.jpg
