Dumble Blue Capacitor
Bombacaototal
Post by Bombacaototal »
I was looking into late 80's/ early 90's ODS and noticed that frequently HAD used those blue capacitors.
I have been on a hunt trying to find out what they are. I have seen an early amp (maybe 18X serial - don't recall exactly) which had a A/E stamp on the blue caps at the PI. The one on the picture attached has an M stamped, I am wondering if these are ITW?
RadioShack has some blue capacitors but they are rated 250V, which I don't think it would be appropriate for the PI (which he usually uses 600V or 630V).
I know that in late 80's RadioShack had Archer capacitors, but I could not find blue ones rated around 600V.
Any insight?
Charlie Wilson
Re: Dumble Blue Capacitor
Post by Charlie Wilson »
Maybe this.
CW
Bombacaototal
Charlie Wilson wrote: Wed Apr 05, 2023 7:32 pm Maybe this.
CW
Which caps are these Charlie, could well be
ITW seems to have the MF as well (attached)
Bombacaototal
Here is the one with the A/E stamp, #167
Charlie Wilson
The one in the picture I posted is Xicon. I think the MF may indicate metallic film or something like that. The Xicon are a bit bright so maybe they are not the HAD approved caps. I believe AE is Arco.
CE
67plexi
Post by 67plexi »
I have a few AE .1uf @ 630 volt
Bombacaototal
67plexi wrote: Wed Apr 05, 2023 8:59 pm I have a few AE .1uf @ 630 volt
Will send you a DM
erwin_ve
Post by erwin_ve »
The M stamp might be Panasonic. On their radial electrolytics is also a M stamp.
And they have a discontinued ECQ m series film cap.
Bombacaototal
erwin_ve wrote: Thu Apr 06, 2023 9:24 am The M stamp might be Panasonic. On their radial electrolytics is also a M stamp.
Thanks for the input Erwin, I will surely do some research on Panasonic, many thanks.
67Plexi, looking forward to your reply
