1) The FET circuit combines the supply voltage and switched input on the jack switch, as well as no connection to the output. I'm sure my drawing needs some correction, but what is the best way to draw that in?
2) The SSS#002 schematic suggests a non-adjustable fixed bias with a 3k3 dropper off of one of the HT secondary legs, and one of the layouts involves such a source with an ODS style adjustable pot with the 22K tail/ 10K adjustable pot. How would you correctly design adjustable fixed bias for the SSS#002 amp? Would you not use the Fender Twin bias tap?
Thanks,
Brian
REDRAW:
NEW "V7" VERSION ADDED 01-24-2024-- NOVAL SOCKETS ALIGNED TO LAYOUT, MANNING SIM VOLTAGES ADDED
NEW "V6" VERSION ADDED 11-13-2023-- EDITED RCOLGAN BIAS. THANK YOU, MARTIN! I'LL GET IT EVENTUALLY!
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
NEW "V5" VERSION ADDED 11-12-2023-- "V-" SUPPLY CIRCUIT CORRECTED TO TOP OF SUPPLY CAP, NOT BIAS POT LEG
NEW "V4" VERSION ADDED 11-09-2023--Changes notated on schematic. MANNING FILTER & BIAS MODS ADDED.
NEW "V3" VERSION ADDED 11-06-2023--
ORIGINAL:
